» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 11-22-2005, 12:35 PM   #1 (permalink)
Date registered: Nov 2005
1976 300D Trunk and Door locks switch wont work
Helo everyone, Im new Here and I was just wondering if I may be able to find answers here about my 1976 300D. Any help apprecieted.
Here's the problem My mercedes has been sitting in the garage for 8 years now because of a transmission problem. This summer we decided to put it on the road but we ran into a problem. The Trunk does not want to open. we turn the key and push the button in and it wont click or nothing. The door lock buttons in the car wont work either. I'm thinking a fuse but not quite sure. My dad thinks that in order for the trunk to open it needs some kind of power. Please Help. I cant move the car until we get into the trunk because the wheel parts r in it. Also the windows row down with the button. My car is Fully Loaded Everything elecric.
eageclaw is offline   Reply With Quote
Old 11-22-2005, 01:13 PM   #2 (permalink)
BenzWorld Elite Host
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
RE: 1976 300D Trunk and Door locks switch wont work
Is this a W123 chassis or W115 chassis 300D? There were two types made in 1976.
W123
W115
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
Fifth Annual Texas Mercedes-Benz Get Together, June 5, 2010. Click Here for Info
H-TownBenzoboy is offline   Reply With Quote
Old 11-22-2005, 10:50 PM   #3 (permalink)
W123. Thanks
Old 11-23-2005, 06:18 AM   #4 (permalink)
Date registered: May 2005
Vehicle: V8 W123
They are vacuum controlled, not electric. You may be able to get under the hood with a vacuum pump, and provide the needed vacuum to the system.
Even without it, you should be able to access the trunk with the key.
blkchambers is offline   Reply With Quote
