» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 11-20-2005, 05:47 PM   #1 (permalink)
peter811's Avatar
Vehicle: 1984 300D
Antenna Mast
When i bought my car it came with a broken antenna mast. My father gave me a new antenna mast, and a brand new motor w/ antenna mast.
Here is my problem, I installed the new antenna mast, and I found out that there is a small, but important difference. the aftermarket antenna mast is not compatible w/ the stock fittings, It will extend and contract w/ the motor, but I have no way to stop it from fully extending and falling out.
I don't want to use the New motor w/ antenna mast until my old motor burns out.
I want to replace the old mast, but I can't find any place that sells a mast that will properly fit.
Can someone help me!!
peter811 is offline   Reply With Quote
Old 12-04-2005, 08:18 AM   #2 (permalink)
plurkje's Avatar
Date registered: Oct 2005
Vehicle: 1985 300TD Wagon
RE: Antenna Mast
If it's a Hirsmann it's been sold at any MB dealership
plurkje is offline   Reply With Quote
Old 12-04-2005, 01:37 PM   #3 (permalink)
MBeige's Avatar
Date registered: Jan 2004
Vehicle: 83 300D, 89 190E, 90 300TE, 93 190E
RE: Antenna Mast
Assuming that the aftermarket antenna mast is correct, there is a small gear inside the mechanism that tells the motor when to stop. It might simply be loose.
If it's intact, you have a wide variety of masts to choose from if you try Autohaus AZ. I got the $30 one, last item, flat top peg with "h" for Hirschmann.
http://autohausaz.com/search/productx.aspx?sid=lj0w2ky1thj5u1eupqjnzr45&makeid= 800016@Mercedes&modelid=1193778@300DT&year=1983&ci d=13@Body,%20Trim%20%26%20Lighting&gid=1332@Antenn a
MBeige is offline   Reply With Quote
