Side mirror removal - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 10-18-2005, 06:43 PM Thread Starter
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
Quoted: 10 Post(s)
Side mirror removal
How do I remove the driver's side mirror adjustment?
I'm wanting to remove the driver's side mirror. I pryed off the interior triangle and got access to the three screws, but unless I take the adjustment arm off, it isn't going anywhere.
Gregs300CD is offline
post #2 of 9 (permalink) Old 10-18-2005, 07:06 PM
MB-Owner-in-ind's Avatar
Date registered: Aug 2004
Vehicle: 83 300D
RE: Side mirror removal
Look on the side of the adjustment opposite of the arm and you will find a small plastic piece thats wedged down inside a channel. Use a sharp point to remove the piece and the arm will come off.
MB-Owner-in-ind is offline
post #3 of 9 (permalink) Old 10-18-2005, 07:45 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 204 Post(s)
Just a shot in the dark, but I think the adjustment lever has a screw on it. Hard to see it.
MBeige is offline
post #4 of 9 (permalink) Old 10-18-2005, 08:08 PM
Vehicle: 83 300D
There might be a screw, I really don't remember one and it has bee a while since I did it. But, I did the removal thing without looking at a book first because thats the way I am. I don't consult a book until I can't figure it out.
post #5 of 9 (permalink) Old 10-18-2005, 08:37 PM
MBZ300CD's Avatar
Date registered: Oct 2004
Vehicle: 1984 300CD, 1983 240TD Euro
Quoted: 62 Post(s)
This is TOO easy. SEE STEP 2.
http://mb.braingears.com/123_DISK2/program/Chassis/72-270.pdf
USE the MANUAL!!!
[8D]
Gary
1984 300CD, Exterior Code # DB877 Petrol - Blue/Green Interior Code #155 MB-Tex Creme
"Even more attractive than this coupe's classic lines are it's classic over-the-road capabilities".
Mercedes-Benz of North America 1984 range brochure
SR 395 @ Mono Lake, CA
MBZ300CD is offline
post #6 of 9 (permalink) Old 10-19-2005, 10:06 AM Thread Starter
Gregs300CD's Avatar
Vehicle: 1982 300CD
Quoted: 10 Post(s)
I saw the rectangular ribbed cover piece, but I was hoping to hear if I push it in, pull it out, slide it forward or back? I wanted to know something before I attacked the plastic with a mini screwdriver and got it all scratched and dented.
post #7 of 9 (permalink) Old 03-15-2015, 11:15 AM
Date registered: Jan 2010
Vehicle: 300CD, 300D 2.5
I am replying to this old post with hopes that you are still an active member.
Regarding the thread "Side mirror removal..." I am not clear how to remove the adjustment lever.
I, like many others do not have a manual and the MB.braingears is no longer available on-line.
This model is a 82 300CD with a right side mirror that someone decided to break the casting structure that houses the adjustment mechanisim (outside the vehicle).
udakhan is offline
post #8 of 9 (permalink) Old 03-15-2015, 11:25 AM
MB-Owner-in-ind-
Perhaps you are still an active member and can clarify the instructions you provided to Greg so many years ago now.
I am not finding much luck removing the side mirror adjustment knob from a '82 300CD. You said, "....a small plastic piece thats wedged down inside a channel."
Is the channel you speak of on the side of the knob that faces the door (e.g. to the outside)? I am puzzled as to how one would access the plastic piece wedged therin even with the three screws of the mirror bracket removed?
Thanks!
udakhan is offline
post #9 of 9 (permalink) Old 03-17-2015, 05:31 AM
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: 2013 MINI Copper S Clubman, '84 300CD-weekend car
Quoted: 139 Post(s)
The pics may help.
Name:	mirror, external 002.jpg
File Type: jpg Screen Shot 2015-03-17 at 8.29.45 AM.jpg (20.4 KB, 52 views)
'13 MINI Cooper Clubman S-daily driver
'84 CD-weekender!
Rmac58 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
