Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 10-03-2005, 04:34 AM   #1 (permalink)
~BANNED~
kiwiya2001's Avatar
Date registered: Jun 2005
Send a message via MSN to kiwiya2001
is transmission problem?! 722.4 or 722.1 ?!
why after start.Trample the accelerator lightly .Change three gear after from two gear starts.But change four gear right away again.Time that three gear appear is very short.And about at soon 40km change to four gear. With as for the acceleration is very slow and heavy to drag along. my car is 1982 w123 200 vergaser. transmission is 722.409 someone who can tell me . thank you~~[:)]
kiwiya2001 is offline   Reply With Quote
Old 10-03-2005, 08:13 AM   #2 (permalink)
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
RE: is transmission problem?! 722.4 or 722.1 ?!
Maybe adjusting this can solve your shifting issue?
Gregs300CD is offline   Reply With Quote
Old 10-03-2005, 08:24 AM   #3 (permalink)
~BANNED~
kiwiya2001's Avatar
I tried.If turn again tightly.The accelerator tramples to become exactly soon a steel lock not enough long...[xx(]
Old 10-03-2005, 06:15 PM   #4 (permalink)
esde's Avatar
Date registered: Feb 2005
Vehicle: 1971 416, 1984 300td
My first 300td had a fast 2-3-4 shift, as you describe. RPM was too low for 4th when it shifted and was very slow. Ended up being a vacuum problem. The line that goes to the transmission was cracked, but slightly. HTH, Seth
esde is offline   Reply With Quote
Old 10-03-2005, 11:07 PM   #5 (permalink)
~BANNED~
kiwiya2001's Avatar
The line that goes to the transmission was cracked? Is your meanings the transmission's kick-down steel wirehttp://www.mercedesdismantlers.com/image004.jpg
Old 10-03-2005, 11:14 PM   #6 (permalink)
~BANNED~
kiwiya2001's Avatar
My car uses originally 722.121 because of damaging.So I change 722.409 I know 722.409 is an usage on 6 engine of the cylinders 260E. Thus can the method is all right?! http://www.autoimport.dk/reservedele/prissider/?side=Gearkasser+automat%2C+brugt&model=Diverse
Old 10-04-2005, 04:55 AM   #7 (permalink)
esde's Avatar
Not the cable, the vacuum line was cracked. Seth
Old 10-04-2005, 04:58 AM   #8 (permalink)
~BANNED~
kiwiya2001's Avatar
vacuum line ?!http://tw.pg.photos.yahoo.com/ph/kiwiya2001/album?.dir=4bd3&.src=ph&store=&prodid=&.done=http% 3a//tw.photos.yahoo.com/ph//my_photos
this is my photo...can you tell me where is the vacuum line. thank's
Old 10-04-2005, 05:09 AM   #9 (permalink)
~BANNED~
kiwiya2001's Avatar
http://users.vnet.net/w123d/w123d/imagies/20242a.gif
is this?!
Old 10-05-2005, 02:25 PM   #10 (permalink)
~BANNED~
AMSOIL300CDT's Avatar
Date registered: Jan 2005
Vehicle: 85 C123 TurboDiesel, 87 190e 2.6
Location: Heilbronn am Neckar, Baden-Württemburg, Deutschland ; Ft. Myers Beach, Florida, USA
Send a message via AIM to AMSOIL300CDT
Gregs300CD - 10/3/2005 10:13 AM
if u turn this screw adjuster IN, it will shift sooner......
if u turn the adjuster screw OUTWARDS, it will allow more time/RPM's in between shifts...
is this what your problem was?
AMSOIL300CDT is offline   Reply With Quote
