got my new climate control unit
915 views 1 reply 2 participants last post by  MBeige
but same thing i had center vents for about 3 min that is it so after spending $200.00 what can it be???? can it be the electronic connector's(windings) on the manifold on the blower box[:(][:(][:(]any ideas
I've posted about my success in making the center vents work:
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1182618&posts=1&fid=10
Hope this helps. Sorry about the $200 maybe somebody needs it and you could resell? [|)] Or return it if they accept it, but since it's an electrical... dunno... goodluck on that
The pain about that center vent flap actuator is the spring inside it. If there isn't enough vacuum, the spring will overcome the weak vacuum and will therefore close the flap. If there is sufficient vacuum coming in the actuator itself, then it should open.
At least this is so in my case [xx(]
