What does it mean when the "BRAKE" light flashes while you are driving ?????? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 01-13-2004, 05:45 PM
KamiL
Guest
Posts: n/a
Quoted: Post(s)
As I was driving on the highway today my red light that says BRAKE started to flash. It really didn't flash when I was stepping on the brakes, mainly when I accelerated the car. My rear brakes have been squeeking for a while now but when i checked them they seemed fine.
What does that mean ? Anybody have any ideas ?
post #2 of 10 (permalink) Old 01-13-2004, 06:29 PM
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
RE: What does it mean when the "BRAKE" light flashes while you are driving ??????
Sounds like the fluid level or the parking brake pedal is not returning. Probably the level.Why is it low?? Check your pads- if they are low do not add fluid!! When you do the pads the level will rise. Make sure all wheels are dry, meaning calipers are ok.....
BENZDOC is offline
post #3 of 10 (permalink) Old 01-13-2004, 06:33 PM
BF_JC230's Avatar
Vehicle: 2005 w203, 2013 Town & Country
Send a message via AIM to BF_JC230
Just a huntch but could it be a pad wear indicator? there are only a few electrical senders that tell that light to come on - even a cheap chilton or haynes manual will give you the wire diagram. - Jake
Best retrofit to date...Code 248!
BF_JC230 is offline
post #4 of 10 (permalink) Old 01-14-2004, 02:16 AM
Andrew Noakes's Avatar
If the red BRAKE lamp flashes while driving it indicates low fluid level, which might mean the pads are getting worn. It should also light up when you apply the parking brake.
There is a separate pad wear indicator lamp to the left of the BRAKE warning lamp - a yellow background with a (O) symbol.
Andrew Noakes is offline
post #5 of 10 (permalink) Old 01-14-2004, 01:45 PM
KamiL
Guest
Posts: n/a
Quoted: Post(s)
do the rear brakes have sensors on them ???[?][?][?]
post #6 of 10 (permalink) Old 01-14-2004, 01:56 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 714 Post(s)
No -- only the front brakes have sensors.
GeeS is offline
post #7 of 10 (permalink) Old 03-04-2004, 10:58 PM
MBeige's Avatar
Date registered: Jan 2004
Vehicle: W-1-2-3 Go!
Quoted: 204 Post(s)
Andrew Noakes - 1/13/2004 2:16 AM
Sorry to bump an old topic, but I noticed just now that only at certain times, when I step on the brake (to the limit, like when stopping from a back-up) the "(O)" yellow brake warning light goes on, but when I release slightly, it goes off but I'm still stepping on the brake pedal. What does this mean?
But on the traffic light, there is no yellow warning light even if I'm stepping it maxed. I checked the fluid level, it's still maxed out.
Does this really mean my brake discs are wearing out? I can't say if it's the front or rear brakes that are affected.
On a side note, I do notice that when I brake hard, it goes to one side (left) slightly. This could still be caused by steering wheel free play, as I haven't had the links checked yet.
Thanks.
MBeige is offline
post #8 of 10 (permalink) Old 03-06-2004, 04:22 AM
Pads with a wear indicator have a wire buried in the pad material. When the material wears down the wire is exposed and when it touches the disc it completes the warning lamp circuit. I guess is the disc was slightly ridged or warped, the wire might touch in some parts of the disc and not in others.
So, sitting at lights with the brakes on you get no indicator lamp, but when you're moving the disc is rotating and the lamp lights when you hit the brake pedal. I guess.
What it means is that the pads are worn - or possibly there's a gremlin in the warning light circuit.
The pull to one side under braking could also be a symptom of worn pads, or maybe a sticking caliper.
post #9 of 10 (permalink) Old 03-06-2004, 04:28 PM
MBeige's Avatar
Quoted: 204 Post(s)
It seems that reasoning would tell me the pads are worn, because the car turns to one side on hard braking, and the (O) flashes. I'll have it checked at a known brake repair shop here.
Thanks! If anything comes up I'll update. [:)]
MBeige is offline
post #10 of 10 (permalink) Old 03-09-2004, 05:58 PM
MBeige's Avatar
Quoted: 204 Post(s)
One thing I did notice was the (O) light turns on (sometimes bright, sometimes blinking) ONLY when I'm backing up, but when I'm driving forward, it rarely turns on.
Haven't checked yet at the brake shop though. Any ideas?
MBeige is offline
Closed Thread
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
