» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-13-2008, 07:01 PM   #11 (permalink)
akimball442
akimball442's Avatar
Date registered: Nov 2007
Vehicle: '73 450SL, '78 300CD, '88 300SE, '84 Olds 98, '81 Cadillac Coupe Deville
The calipers on my 123 are SHOT. I have the bendix type. I also have the rebuild kits sitting on the table in front of me. Bad calipers could cause one side to drag, that is what's wrong with mine. The driver front (most likely to have trouble, shortest line) has the outside piston stuck. It wont move in or out. I'm going to have a fun time freeing it up.
I have to get my 126 on the road so I can spend some time taking them apart and overhauling them. It's not really a major job, but it's tricky on this particular type, because you're going to need to keep one piston in while you get the other out. You'll need to find a clamp that will allow that, and keep your fingers out of it when you hit them with compressed air. I read the instructions on the manual CDs, the only thing I'm worried about is that it says the pistons have to be in basically perfect condition. They are supposedly chrome plated. I'm thinking if you carefully buff them that would be good enough, but you dont want to use anything too abrasive or it'll corrode fast and you'll be stuck in the same situation.
Remember. Moisture + heat = instant rust.
I'm giving it a shot anyway, for $15 and a few hours, it's worth it, but i have a funny feeling I'll end up replacing the calipers.
Aaron-
akimball442 is offline   Reply With Quote
Old 05-13-2008, 07:20 PM   #12 (permalink)
240Dbio
Date registered: Jan 2007
thanks for your advice, i believe my pistions go in and out, but i think there slowing down hense one brake is WAY lower then the other. im going to call mercedes tomorrow and asked them what type of caliper i have. hopefully mercedes is not to expensive oher wise ill two day from offline
1983 240D 210K
240Dbio is offline   Reply With Quote
Old 05-13-2008, 08:08 PM   #13 (permalink)
glutton4punishment
Date registered: Dec 2006
Vehicle: 1983 240D in pieces 1977 280SE awaiting euro 280 transplant 1990 Audi 200 1995 Audi S6 avant
Send a message via AIM to glutton4punishment
The brand should be stamped on the caliper, it may be hard to find after 25 years of rust and gunk.You'll be able to find it with a can of brakleen and a wire brush. I'd be surprised if the stealership can tell by the VIN what brand were put on your car.All mine have been ATE and Girling, I forgot Bendix were put on these as well.
glutton4punishment is offline   Reply With Quote
Old 05-14-2008, 02:37 AM   #14 (permalink)
Rmac58
Rmac58's Avatar
Vehicle: '83 300SD-daily driver '84 300CD-weekend car
Send a message via Yahoo to Rmac58
I recently replaced my front calipers on the SD, they were Bendix, but when you replace them, you do both fronts, or rears. So you can put whatever you want on.
I understand MB used Bendix and ATE. Girling is the booster manufacturer, didn't know they made calipers as well. Anyway, a difference between Bendix and ATE is the shape of the retaining pad spring, the Bendix used a wire bent to specs. ATE used a flat, wide piece of spring steel.
Hope this helps.
'83 SD-daily driver
'84 CD-weekender!
Rmac58 is offline   Reply With Quote
Old 05-14-2008, 04:59 AM   #15 (permalink)
240Dbio
are you talking about the metal piece that holds the pads in? or the sprint for the parking brake?
Old 05-14-2008, 05:41 AM   #16 (permalink)
240Dbio
yeah mercedes was no help; anyone that knows your calipers are these certain brands; how did you determine it? where did you see there little logo?
Old 05-14-2008, 05:59 AM   #17 (permalink)
Gregs300CD
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
I prefer ATE.
You could remove a pad and get an exact replacement at the parts store, or you can replace the caliper and get appropriate pads then.
(ATE put the logo on the round part, but it might be covered in grime.)
Gregs300CD is offline   Reply With Quote
Old 05-14-2008, 06:31 AM   #18 (permalink)
240Dbio
in all its glory ATE. I called mercedes and they wanted a half a tank of gas 38.54 something like that. was nice enough to give me the part number
001-586-73-43 ate (rear)
buying offline and twodaying it shows you to over charge me. im paying the same price probably but.....o well
Old 05-14-2008, 06:50 AM   #19 (permalink)
240Dbio
ahhh i love america 32.45 for two kits with shipping. be here on friday from **********.com vs. mercedes benze 38.54 for one kit and i have to waste my gas 20-30miles to get to them. twice! onces to pay, and once to pick up.
Old 05-14-2008, 06:52 AM   #20 (permalink)
240Dbio
i didnt know i wasnt allowed to name drop websites. umm well MBparts with a "buy" in front of that
Whats Going On!? scottd825 W140 S-Class 7 11-01-2006 03:52 PM
Whats this here?? Binny W201 190E, D-Class 12 10-17-2006 12:31 AM
Does original CD changer plays only original audio CD's? quepao W163 M-Class 8 04-07-2006 09:10 AM
when someone replaces the original equipment for non original equipment... eso7 W124 E,CE,D,TD Class 5 10-12-2004 05:11 AM
Whats the best launch method....whats better (for acceleration) 4 or D Mike G R170 SLK Class 4 12-29-2001 10:36 AM
