» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-05-2008, 10:46 AM   #11 (permalink)
Gregs300CD
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
I've tried starting my car while it was in drive.
The key turns but the engine doesn't.
Sometimes the steering wheel will lock, keeping the key from turning, but I'm sure you know that.
Gregs300CD is offline   Reply With Quote
Old 05-05-2008, 02:40 PM   #12 (permalink)
cheapold280ce
cheapold280ce's Avatar
Date registered: Sep 2007
Vehicle: 1978 280ce euro bought for $300.00
79Mercy is right because I start my car by turning the key and holding it in start while I jiggle the shifter around park until it starts.
cheapold280ce is offline   Reply With Quote
Old 05-08-2008, 11:07 PM   #13 (permalink)
maasmike
Date registered: Oct 2007
Vehicle: 82 230E, 2001 ML320
Can the ignition lock be removed without grinding off the pin at the column (as done by dieselgiant)?
maasmike is offline   Reply With Quote
Old 05-09-2008, 05:30 AM   #14 (permalink)
79Mercy
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
if the key is turned to the 1st position.
'79 280CE with 210,000 miles and still going strong!!
79Mercy is offline   Reply With Quote
Old 05-13-2008, 08:37 AM   #15 (permalink)
maasmike
So I finally got the iginition assembly removed from the column, but can someone tell me the trick for removing the wiring harness from the back of it?
Old 05-13-2008, 10:43 AM   #16 (permalink)
Gregs300CD
Gregs300CD's Avatar
Vehicle: 1982 300CD
This page might come in handy...
http://www.dieselgiant.com/repairignitionlock.htm
(Sorry, never actually done that myself either.)
Old 05-13-2008, 06:18 PM   #17 (permalink)
GreaseDiesel.org
GreaseDiesel.org's Avatar
Date registered: May 2008
Vehicle: '78 240D 4-speed greasel
hmm... i don't remember, but it should be straight forward, maybe a small bolt or two???
did you have to do any grinding?
GreaseDiesel.org is offline   Reply With Quote
Old 05-14-2008, 12:08 AM   #18 (permalink)
maasmike
Gents, thanks for the help. Instead of grinding (I couldn't find a grinding bit) I used a metal drill bit to drill out the pin. My problem with getting the wiring harness off was that the key wouldn't fully turn to the 1st position, the steering column lock pin was jammed out. I had to pry it down with a screwdriver to get it to release, and now everything works great. I have spayed the entire works with graphite oil, and now plan on just reinstalling as there was nothing wrong with the tumblers. Now that I have done this if it happens again I know just what to do. Thanks again.
Ignition Key Won't turn rey445588 G-Class 1 02-09-2008 08:21 AM
Turn the key...nothing? Cosmar R/C107 SL/SLC Class 3 10-24-2007 07:43 PM
Smart Key Combination to Turn off Turn Signals Magic Man General Mercedes-Benz 0 09-10-2007 09:04 AM
turn the key and dash lights turn on, no power to starter bob richards General Mercedes-Benz 4 01-13-2006 07:48 AM
'86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190E, D-Class 4 04-01-2002 12:29 PM
