Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 03-08-2008, 09:47 PM   #1 (permalink)
jimmyl's Avatar
Date registered: May 2004
Vehicle: 1985 300TD, 1980 240D x 2
Replace clutch slave cylinder and bleed clutch
Well, the reason for replacing the clutch slave was just a horrible hemorrhaging from the seam between the slave and the tranny bell housing. No problems at all with operation.
So, pulled the Squash into the garage and put the front up on ramps
Here is the slave on the passenger side of the tranny. You can see I think where it has been oozing down the side of the tranny. {oil under there too from oil filter housing gasket}
I'm not sure if this is advised, but first I clamped off the line from the brake reservoir.
Next is where I messed up a little bit. I removed both of the 13mm bolts holding the slave to the tranny.
**Notice gasket in between slave and tranny**
What I should have first done is loosen the 12mm fitting to the fitting on top of the slave. Doh! I was still able to get it loose, but it simply would have been better to break that fitting loose while still secured to tranny. Lesson learned.
Here are old and new slave cylinders, along with gasket. There is a rubber seal/bladder in the front of the slave, and the old one looked horrible compared to the new one.
Jimmy L
I know I can get this thing in the trunk......
jimmyl is offline   Reply With Quote
Old 03-08-2008, 09:49 PM   #2 (permalink)
jimmyl's Avatar
I want to point something out about the gasket. I may be totally wrong about why, but notice there are 2 diagonal channels in the bottom end of the gasket {channels point down}. I believe this is so that if the slave develops a leak it gives the fluid a place to run out and not get all in the bell housing. Maybe not......
You can see the marks from this on the tranny bell housing
OK, back in with the new slave
Put your 2 13mm back in and tighten down.
Next took me quite a while, and you could so profoundly screw-the-pooch here if you aren't careful. You have to thread the 12mm fitting back onto the top of the slave. Be so very careful not to cross thread here. I spent almost 15 minutes trying to make sure I got this right. In the end I was a little hesitant to put the wrench to it as I sure couldn't hand tighten it very far, but it worked out fine thank goodness.
NOW, the dreaded clutch bleeding:
After reading about clutch bleeding over the last 4 years I certainly wasn't looking forward to this. I did a bunch of searching this morning on the various ways to go about this.
I thought about using my still-never used pressure bleeder and bleeding from the slave fitting up through to the brake reservoir, but there really isn't any way to control the flow. It is just "on" or not.
So, basically I did pretty much the same thing, only using the right front brake caliper and reverse bled.
Worked well for me.
First I went and bought 3 feet of 3/16 fuel line and some Dot 4 brake fluid. I filled the brake fluid reservoir to full and I removed the clamp on the line from said reservoir that I installed earlier. I attached the 3/16 fuel line to the slave bleed nipple and opened it some.
The thought was to maybe let some fluid run down from the reservoir then connect it to the RF brake caliper bleed nipple. And, that worked pretty well. When I got a little drip I connected to the caliper nipple and opened it up. {Uh, btw, I opened it a little too far and puked brake fluid out during pedal pumping. Just an fyi}
So, just to clarify at this point, the brake fluid reservoir is full,
3/16 hose is attached at the slave cylinder and at the RF brake caliper and both bleed nipples are loose.
Then you simply step into the car, with the hood open and leaned/standing out the driver's door so you can see the line coming into the brake fluid reservoir and pump on the brake pedal and watch for bubbles to start floating up. {Which they did!} Oh, and you do nothing with the clutch pedal during this.
Now, like I said, I first left the RF caliper bleed nipple too loose and it oozed quite a bit of fluid, so I tightened everything back, opened them up a tad and pumped the brakes some more. When no more bubbles came up, but I could tell fluid was entering I tightened both nipples, started the car and prayed it would shift into reverse with out grinding. {I chose reverse in case the car crammed into gear and wanted to "go". Better to shoot off the ramps than over them.}
We'll see after I drive it awhile if I have to re-bleed. I'm hoping not.......
Clutch Slave Cylinder AMGMAL V-Class 4 03-09-2008 09:56 AM
Clutch Slave Cylinder Problem Sizzle-Chest Vintage Mercedes-Benz 2 07-15-2006 09:34 AM
clutch master cylinder&slave aggragated G-Class 16 12-11-2005 02:09 PM
clutch slave cylinder inkblotz G-Class 21 08-08-2005 03:54 AM
Clutch Slave Cylinder - Fording or Not Jim G. G-Class 5 06-11-2005 10:29 AM
