Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 02-16-2008, 12:37 AM   #1 (permalink)
Date registered: Feb 2008
Advice on W123 mercs...
G'day all!
I'm new here, looking at buying my second car and I've decided I want a Mercedes-Benz.... (In Australia...)
So far my favourites in my price range ( up to 5000) have been the W123 and W114 chassis cars.
Really I'm looking at 240Ds and 280CEs but other W123 sedans would be good too.
My question is: what should I look for when buying one? What are the problem areas and things to look out for? Anything specific or just the usual car things?
Thanks!
will280CE is offline   Reply With Quote
Old 02-16-2008, 06:12 AM   #2 (permalink)
POS
POS's Avatar
Date registered: Oct 2005
Vehicle: 1983 500SL AMG, 1982 300D
Welcome to the boards. Excellent suggestion is to search - especially in the w123 forum. It's a common question with a variety of answers; you'll need to spend the time doing your homework.
http://www.benzworld.org/forums/w123...d-td-te-class/
1983 Black 500SL AMG with 5-spd manual - 44,000 miles
1982 Blue-grey 300D - 64,000 miles
POS is offline   Reply With Quote
Old 02-16-2008, 09:21 AM   #3 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Auto transmission will require rebuilding.
HVAC system will require work.
Kent Christensen
Albuquerque
Old 02-16-2008, 04:11 PM   #4 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
^^How do you know this? The tranny maybe fine and the AC maybe fine. My trannny has close to 210,000miles and it shifts great, the AC has a small vacuum leak but can be repaired.
'79 280CE with 212,600 miles and still going strong!!
79Mercy is online now   Reply With Quote
Old 02-16-2008, 06:18 PM   #5 (permalink)
84bioburner's Avatar
Date registered: Jul 2007
Vehicle: "Sadie"1984 w123 White/blue 169K and counting. The Grey POS or parts car 83 grey/ palimino
Once you find a good candidate, its documentation,documentation,documentation. And rust!
84bioburner is offline   Reply With Quote
Old 02-16-2008, 06:50 PM   #6 (permalink)
Thanks for the replies.
Yeah I used to have a 74' Celica that had a gearbox problem, so I whipped it out and just replaced it, so I suppose it won't be too hard to do that.
Are there many good examples? What is a reasonable asking price from a dealer for an example in reasonable condition?
Old 02-16-2008, 11:48 PM   #7 (permalink)
Merc_aficionado's Avatar
Date registered: Mar 2007
Vehicle: 2006 smart forfour 1.5 Pulse | 1992 BMW 525i M
I know someone in Brisbane who drives a W123 wagon, I can PM you his email address so that you can ask him a coupla questions. He'll be able to give you advice relevant to Australia.
I wouldn't go for a W114/5. They are just too old to make a comfy daily driver. W123's are much more refined.
As for which model... the 230E gives the best compromise between power and fuel economy. Most 230E's also has a/c and cruise control. If I remember correctly Australian Mercs has the manual a/c system and not the complicated climate control system as found in US cars.
My advice is to go look at some examples, take LOTS of pics and post them with detail here, so we can give opinions / advice.
Hope this helps.
Merc_aficionado is offline   Reply With Quote
Old 02-17-2008, 10:27 PM   #8 (permalink)
Benzzy280's Avatar
Date registered: Dec 2007
Vehicle: 1981 mercedes benz 280e
hello i live in melbourne. i own a 1981 280e. Great car. I did a lot of work to fix it up but they aint extremly hard to work on i found. But yeah i would look out for rust obviously so look under the wheel arches and in the boot, take the side plastic cover off (very simple) and look behind it where the wheel arches are. Also make sure the car stays at good temperature, radiators are like $350 bucks and also it could mean a head gasket problem which ive found can be between 1500 and like 2500 bucks. So see if the oil is muggy and whitish and you can also the air filter - there is a black tube that goes into the top of the air filter, pull it off and see if theres a white muggy substance inside to (this applies to the 2.8 liter, i dont know bout the other engines). And yeah check for major oil leaks and tranny leaks and yeah just good service info helps. Just like any car its best to pay a little more and get a good one then buy a cheaper shit one, you will quickly see your repair bill go up very quickly.
Benzzy280 is offline   Reply With Quote
Advice needed, 99 CLK Wheels on W123 Woody6 W123 E,CE,D,CD,TD,TE Class 4 12-08-2007 07:47 PM
W123 steering & suspension parts advice? hotwheelbill W123 E,CE,D,CD,TD,TE Class 5 12-24-2006 07:38 AM
w123 newbie - looking for some advice onegermanandaswede W123 E,CE,D,CD,TD,TE Class 10 05-04-2006 11:21 PM
New to to the W123 - Some Advice Sought - bit long, but really would like you guys opinion. Uncle Ants W123 E,CE,D,CD,TD,TE Class 58 10-31-2005 05:15 AM
Advice on buying a w123 230E - with or without Air Con? cbm W123 E,CE,D,CD,TD,TE Class 2 02-14-2005 07:43 PM
