» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 01-18-2008, 06:57 PM   #1 (permalink)
Date registered: Jan 2007
confused
eBay Motors: Mercedes 123/W123 240/300 CD/D/TD RH Amber Corner Light (item 280193669030 end time Jan-23-08 15:32:29 PST)
I bought this piece off ebay..... and it doesnt fit my W123 240D mercedes american. It says european style; i already plan to return it, but i really wanted it to fit. any suggestions? The connections are different.
1983 240D 222K
240Dbio is online now   Reply With Quote
Old 01-18-2008, 07:07 PM   #2 (permalink)
frans-c's Avatar
Vehicle: 1985 W123 Mercedes-Benz 230E
As far as I know, the US indicators have some sort of parking lights, i.e. they light up when you turn the headlights dial to the first notch.
Can't you simply switch the two different connectors, or does the US variant have two bulbs in its housing?
And you know what, I doubt returning them is going to be worth all the effort involved...
F R A N S
1985 Mercedes-Benz 230E
340 000 km / 211 000 miles
Full MB service history...still
frans-c is offline   Reply With Quote
Old 01-18-2008, 07:24 PM   #3 (permalink)
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: '83 300SD-daily driver '84 300CD-weekend car
Send a message via Yahoo to Rmac58
I recently replaced a corner light on the SD, it came with the wrong socket, and an orange bulb, went to a bone yard, and bought a correct one for a buck.
'83 SD-daily driver
'84 CD-weekender!
Rmac58 is online now   Reply With Quote
Old 01-19-2008, 12:38 AM   #4 (permalink)
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: 77' 6.9, 74 240D, 76 300D, 1996 Ram 5.9L Cummins
They're all the same in the W123's....are you sure you fitted it properly? You should be able to swap the twist bulb connector and put it into the lamp head.
Take a picture of it and post it.
I have one lying around. Karugs has the other.
1977 - W116 - 6.9
1976 - W115 - 300D - Disassembled
1974 - W115 - 240D 4 SP Manual - Almost under Turbo OM617 Power!
diametricalbenz is offline   Reply With Quote
Old 01-19-2008, 12:01 PM   #5 (permalink)
i got it for fit in. the whole orage housing. but the plastic housing that surrounds the bulb is a two prong and the new one is a two prong, but it doesnt connect with my old eletrical socket. So i tried using my two proung (old plastic bulb casing) but it really doesnt fit i can jam it in there and it will hold. and i think thats what ill do. inless anyones got any ideas
Old 01-19-2008, 12:10 PM   #6 (permalink)
frans-c's Avatar
Some photos to clarify what you mean, maybe?
Old 01-19-2008, 01:39 PM   #7 (permalink)
ok you can see the first picture is the new one and it has two outside prongs the second one is the electrical connection and you can see the new one wouldnt line up with that believe me ive tried it. the third picture is the old bulb connector. it has three outside prounds that connect the bulb casing to the lense. kinda see what im seeing?
Old 01-19-2008, 01:43 PM   #8 (permalink)
ouctyre dudbt kiad last tune
Old 01-19-2008, 02:00 PM   #9 (permalink)
frans-c's Avatar
Yeah, that new one is the Euro connector. Can't you just use your old one? It ought to screw into your new lens.
Old 01-19-2008, 02:23 PM   #10 (permalink)
you would think they would make it easy...but NO! i figured i could fit the two bars into this three prong (outside) casing.....but of course it doesnt fit..... I might making a new whoel myself or making one of those slots bigger and see if that works. I dont want moisture to get into it.
Confession of a Neocon (Newly Confused) I am confused and I want to know....... Jakarta Expat Off-Topic 52 04-13-2007 08:32 AM
i'm confused??? benwithabenz W201 190E, D-Class 4 10-17-2006 09:01 PM
IM Confused markcedes G-Class 1 08-29-2005 02:22 PM
So Confused, In need of HELP Bin3maira G-Class 14 09-25-2004 12:54 PM
confused carlssonist The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 12-03-2002 03:06 PM
