» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 10-16-2007, 12:22 AM   #1 (permalink)
g.w.b's Avatar
Date registered: Dec 2006
Vehicle: 300D
Send a message via MSN to g.w.b Send a message via Yahoo to g.w.b
Question part number ore a pick ?
Does the injector pump of the 300D have a gasket where it mounts on to the motor and does any one have a part number ore a pick for it pleas?
Fore same reason it is leaking a lot of oil in that area
1991 160 monza (100 259 km)
1974 w116 300D (890 000 km)
S.A. ROCK
g.w.b is offline   Reply With Quote
Old 10-16-2007, 01:09 AM   #2 (permalink)
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 80 240D 3.0VNTi
You need 1 per injector.
Select Brand
1980 240D 3.0VNTi 220k miles
Modifications (Link): OM617.952, 4-speed manual, GT2256V VNT turbo, W115 300D intake, ALDA/EGR/rack limiter removed, 3.46 diff, 15mm rear sway bar, Pyro/Boost/Exhaust psi gauges, Amsoil bypass oil filter, Mobil1 5W-40 synthetic oil and 15mm rear sway bar.
youtube.com/Turbo617
SuperTurboDiesel.com
Zedd is offline   Reply With Quote
Old 10-16-2007, 03:04 AM   #3 (permalink)
g.w.b's Avatar
Vehicle: 300D
sorry the one Where the pump mounts on to the motor where the 3 bolts hold it
Old 10-16-2007, 04:49 AM   #4 (permalink)
123wagon83's Avatar
Date registered: Mar 2006
Vehicle: 1983 300TDT
Send a message via AIM to 123wagon83
This might help.
http://www.detali.ru/cat/oem_mb2.asp...SGR=045&SGN=01
Unlike Any Other
123wagon83 is offline   Reply With Quote
Old 10-16-2007, 07:56 AM   #5 (permalink)
Date registered: Sep 2006
Vehicle: 1985 Mercedes 300TDt
The gaskets part number is 000 074 82 80. A lot of the time that gasket will start to leak after performing an injection pump timing adjustment.
-Joshua
1985 300TD - "Panzer Wagon" - 4 speed Automatic (722.416), 3.0L turbo, Trap Oxidizer , Garret T3 Turbocharger (12psi), Shimmed ALDA, Uncorked exhaust at downpipe
http://www.cardomain.com/ride/2342943
joshuajeeper is offline   Reply With Quote
Old 10-16-2007, 10:15 PM   #6 (permalink)
g.w.b's Avatar
Vehicle: 300D
thank you Joshua do you have a pick of it?
What's this part number marlinspike W126 S,SE,SEC,SEL,SD,SDL Class 6 02-22-2007 09:14 PM
San Francisco area Pick Your Part Notification kilbrid3 W123 E,CE,D,CD,TD,TE Class 3 06-30-2006 06:54 PM
What Is This Part Number??? Dolphin27 R170 SLK Class 1 06-28-2006 03:49 PM
Can someone tell me what is the name or part number for this part shown in picture! stsintx R129 SL Class 4 01-24-2006 06:58 AM
Need a part number of this..... dewdaltz W163 M-Class 3 11-10-2004 08:51 PM
