Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 10-15-2007, 03:30 PM   #1 (permalink)
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Compressor oil
While removing the alternator last month I noticed there was tons of oil on the bottom of my york style compressor. I'm afraid it may be low on oil since there is alot on the bottom of it, where do I add or check the oil level? Is there a bolt I have to remove, or do I put it in like you would freon? Thanks
'79 280CE with 212,600 miles and still going strong!!
79Mercy is offline   Reply With Quote
Old 10-15-2007, 03:53 PM   #2 (permalink)
123wagon83's Avatar
Date registered: Mar 2006
Vehicle: 1989 560sel
Send a message via AIM to 123wagon83
The oil is injected same port and the refrigerant
Unlike Any Other
123wagon83 is offline   Reply With Quote
Old 10-15-2007, 04:12 PM   #3 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
dang it!!!! Now I have to take it to the mechanic. Thanks
Old 10-15-2007, 04:43 PM   #4 (permalink)
cheapold280ce's Avatar
Date registered: Sep 2007
Vehicle: 1978 280ce euro bought for $300.00
You don't have to take to mechanic to add oil just add one or two oil charge kits. However, if want to fix problem then you have to take to mechanic. Looks like seal on compressor is bad. So adding oil will just cause more oil to leak. You need to replace seals or replace compressor. Maybe it's just one of the o rings on the hoses has blown. Find cause of leak and repair it. Are you still running R12? You can get R12 fairly cheap on ebay the mechanic will charge alot for R12. Save the OZONE have the R12 recovered.
cheapold280ce is online now   Reply With Quote
Old 10-15-2007, 04:49 PM   #5 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
I paid 500 bucks about 5 years ago for a rebuilt compressor and for it to be converted to R134.
Old 10-15-2007, 05:23 PM   #6 (permalink)
123wagon83's Avatar
If the oil is leaking then the r12 is leaking as well if not long gone
Old 10-15-2007, 05:44 PM   #7 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
Well it was more like grease, I thought it was oil. I was just thinking the valve cover gasket was leaking and I replaced it. It may have been the oil from when it was leaking a long time ago, I'll wipe off and see if it comes back. The air is ice cold. Thanks i'll keep you updated.
Old 10-15-2007, 06:04 PM   #8 (permalink)
Date registered: Feb 2007
Vehicle: 1983 300SD, 1984 500SEL, 1985 300DT, 2006 Silverado Z71 crew cab, 1999 Mazda 626 ES V6
If you have only slight seepage of refrigerant oil, which then of course attracts dirt, maybe you do not need to panic. However, if you see a droplet of oil ready to fall off the compressor, at this point I would be concerned. Clean everything as you said, including the A/C compressor, and then check again.
Incidentally, how did that alternator saga end? At some point I lost track of it.
p100 is offline   Reply With Quote
Old 10-15-2007, 06:29 PM   #9 (permalink)
79Mercy's Avatar
Vehicle: 1979 280CE
Yeah, i'll clean it and check it again in a month or two.
PM sent p100
A/C compressor oil leaking mbenzfan79 R/C107 SL/SLC Class 10 08-03-2007 04:56 AM
oil for 99 ML320 a/c compressor sealfly W163 M-Class 4 06-27-2007 06:36 AM
AC compressor oil f1crazydriver W126 S,SE,SEC,SEL,SD,SDL Class 3 05-03-2006 09:12 AM
Compressor oil karugs W123 E,CE,D,CD,TD,TE Class 7 01-27-2006 11:54 AM
A/C Compressor Oil? s32098 W140 S-Class 1 07-22-2004 02:41 PM
