Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 10-16-2007, 03:36 AM   #11 (permalink)
84 bioburner's Avatar
Date registered: Nov 2006
Vehicle: 1984 300D turbo
Originally Posted by p100 View Post
Unfortunately, all the vacuum systems in these cars are interconnected. A leak in one of the actuators of the climate control systems can badly affect the engine shutoff operation. Do as advised by others: Get a vacuum test pump, test the valve first by itself. Then, if the valve if good, proceed to the ignition lock solenoid vacuum valve.
Do you have other symptoms, like harsh transmission shifting, slow or inoperative door locks, or improper air flow through the A/C registers? If not, chances are, your problem is the shut off valve itself.
Warning: if the shut of valve is defective, do not try to replace it by yourself unless you know exactly what you are doing!!!! The reason is there have been cases where people hooked the valve actuator arm too far on the pump rack and as soon as they started the engine, the engine went to full throttle and raced itself to utter destruction! There is no way to shut off a runaway diesel unless you immediately block the air flow. So, if you chose to replace the valve yourself, make sure you know how to do it, and before you start the engine, disconnect the turbo elbow and stand by the intake with a telephone book ready to immediately block of the air intake should the engine start racing.
Also, one should not attempt to shut off a runaway diesel as it can be extremely hazardous. Better a blown engine than a serious injury.
Actually, the trans shifts great. The locks and hvac need work though.
84 bioburner is offline   Reply With Quote
Old 10-16-2007, 04:21 AM   #12 (permalink)
to loss's Avatar
Date registered: Nov 2005
Vehicle: 1982 300TDT 150,000 miles 1985 380SE 130,000 miles 1991 560SEL 81,000 miles (a/k/a the nightmare)
You've gotta get a Mityvac... they're really no fun at all, but a prerequisite for W123 ownership.
"I don't think it's nice, you laughin'. You see, my mule don't like people laughing. He gets the crazy idea you're laughing at him. Now if you apologize, like I know you're going to, I might convince him that you really didn't mean it."
"I love the smell of diesel in the morning... smells like... like victory"
to loss is offline   Reply With Quote
Old 10-16-2007, 09:07 AM   #13 (permalink)
Yea, I know. I saw one in the harbor freight catalog for $38 or something along those lines. I'm gonna stop by napa to see if they are any cheaper (after you figure in shipping). Maybe by the weekend? I'm sure I could fix a ton of sh1t with one.
Help!! Won't shut off 1967230 W123 E,CE,D,CD,TD,TE Class 14 08-20-2007 05:16 AM
ignition lock cylinder & ignition switch lakeside W164 M-Class 2 07-23-2007 05:55 PM
Shut Up! acarter53 Off-Topic 12 04-26-2007 01:58 PM
Won't shut down 84 bioburner W123 E,CE,D,CD,TD,TE Class 1 11-13-2006 10:57 AM
HeLp PleAsE!? 240d won't shut off, even when I press on shut off switch under hood? turbosing777 W123 E,CE,D,CD,TD,TE Class 18 02-19-2005 03:14 PM
