They are the last ones on the bottom of the second box on the page. i have them installed on my car for over a year and they are like night and day!!!
VERY IMPORTANT, people have complained of burnign up alternators with that high voltage bulb. If you are worried use the 60/55 bulbs and be done with it. I installed the 65amp alternator in place of my burnt up 55amp alternator and since then have not had a problem, and i have a high power stereo system and run fog lights at the same time.
Thats my 2 cents
1982 mercedes 300D turbo, straight pipe,k&n filter (used to have but took out and put in stock paper filter),beefed up fuel pump,alda all the way out and then half turn in, newly rebuilt engine(90 thousand miles ago). Warmed up and cooled off every drive
where did you get the 65 amp one? i have the stock euro 300d alternator (dont know if it is different) and i have been running 100w/90w with 80w fogs for over a year now and just recently installed a 1750W system and if i drive fast my lghts dont din with pushing the sound....LOL really though i want a bigger alternator and dont want to do alot of moding.
1977 300D=RIP
1984 300D turbo=RIP
1981 300SD=RIP
1983 380SEL=SOLD
1984 EURO 300D auto now with OM617.952 170k on motor 245k on body=RIP
Current: 1984 EURO 230E auto with 42k (ABS)
Current: 1983 300D 255k saved from Pick N Pull
I got the alternator at pep boys. i just turned in my old 55 ampre and said i want a 65 ampre on it and they had one in stock. just make sure u pop out the old voltage regulator and bolts and screws that u will need for the new one because the new one has non of it.
I think saab has a 115amp one that fits ....
Get Euro lights. H4 cant be beat.
1985 300D Dark Anthracite Grey, 4spd Manual, Euro Bumpers+OEM Tow, Euro Hella 4, 235/15/60 Falken Ziex 15" ACT. Moogs. Bilstein HDs. Vogtland Sport Springs 50mm drop, Muffler Delete Option. 15mm/TD sway bars, SEC brakes. To be Installed: GT2256V. Considering ABS (Do I really want to pull the spindles again?).
1984 TD Smurfette.
OBK #42 4life.
I bought a set for my 1980 chevy pickup. Put on the Xenon bulbs and all. They were crap. I hit a deer and broke one then replaced them with sealed halogen bulbs which worked better. The Hella ones work great buy hella or Euro lights stay away from the cheap diamond ones.
