Vehicle: Thristle Green 1984 300D Euro with OM617.952 TURBO
230E timing belt or timing chain?
i have a euro 230e 1984 yr model and need to know how to tell if it has the belt or chain...can i just look in the valve cover and see it from an angle?
whats the best way to tell if its good?
GDS-Tech-Cars:
1977 300D=RIP
1984 300D turbo=RIP
1981 300SD=RIP
1983 380SEL=SOLD
1984 EURO 300D auto now with OM617.952 170k on motor 245k on body=RIP
Current: 1984 EURO 230E auto with 42k (ABS)
Current: 1983 300D 255k saved from Pick N Pull
It has a single-toothed chain (solex???). Good practise would be to replace every 100k miles, although the mechanic at the dealership says that he has seen samples that've lasted over 250k miles...
You can actually feel the tension of the chain by simply removing the oil cap - that's from what I've read on other forums, haven't tried it out myself.
You should be able to deduce a lot about the chain's condition simply by listening to the motor running. I think some very minor clatter at idle is allowed, but it should go quiet as soon as you give it some gas.
__________________ F R A N S
1985 Mercedes-Benz 230E
340 000 km / 211 000 miles Full MB service history...still
