» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 06-13-2007, 04:01 PM   #1 (permalink)
Date registered: Jun 2007
1980 240D wont start after fuel filter replacement?
I replaced both the in-line and spin on (secondary filter) Car wont start. I was told to fill the spin on filter with Automatic Transmission Fluid. That didn't help. Doesn't even try to start, just turns over. I loosened the nut on top of the filter assembly and used the had pump to bleed the air out but didn't help what's even worse is that my in line filter turns black and chokes off the fuel supply about every 1000 miles or less. Do the fuel tanks on these cars get mucky or is there another filter I am unaware of??? Thanks for any help.
Rangelic is offline   Reply With Quote
Old 06-13-2007, 05:32 PM   #2 (permalink)
blackcat1134's Avatar
Date registered: Aug 2006
Vehicle: 1979 300D
filling your filter with ATF? I don't remember doing that last time, I just read to lubricate the top right with a dab of diesel and filing the actual filter with diesel to remove as much air before priming the engine pump until diesel starts to spill over.
But other than that, yes the fuel tank filter is often a culprit for a few members, but wouldn't/shouldn't be disturbed by you just changing the fuel filters.
Check your inline fuel filters for excess bubbles or discoloration.
1979 300D - 180K miles
blackcat1134 is offline   Reply With Quote
Old 06-13-2007, 06:21 PM   #3 (permalink)
Date registered: Jun 2006
Vehicle: 1981 300CD
Rather than go into verifying the hand pump works or not, or loosening injector lines to purge air etc. etc. Have someone crank over the engine while you spray WD 40 into the intake. Just remove the air filter lid and spray while someone cranks the engine over. It will start, run rough for a few seconds then smooth out. Next time restart it after each filter. WD 40 is basically kerosene.
carnut1 is offline   Reply With Quote
Old 06-13-2007, 06:28 PM   #4 (permalink)
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
You should also get a biocide like Biobor or Startron to put into the tank.
Gregs300CD is offline   Reply With Quote
Old 06-13-2007, 08:28 PM   #5 (permalink)
Date registered: Feb 2007
Vehicle: 1983 300SD, 1984 500SEL, 1985 300DT, 2006 Silverado Z71 crew cab, 1999 Mazda 626 ES V6
No, it isn't. It is about 67% mineral spirits. It also contains about 21% of lubricating mineral oil.
http://www.dek.com/data/wd-40.pdf
p100 is offline   Reply With Quote
Old 06-13-2007, 08:34 PM   #6 (permalink)
Lorbenzo Lammas's Avatar
Date registered: Nov 2005
ATF is too thick to put in the filter. I did that once to mine too, and it took a long time to get started again. I just kept priming like crazy and turning it over, eventually it fired up.
Lorbenzo Lammas is offline   Reply With Quote
Old 06-13-2007, 08:42 PM   #7 (permalink)
Oddly enough, that was what the local MB mechanic recommended to me. I never tried it though. I think the Lubro Moly diesel purge works much better for cleaning the injectors. Some people add a quart of transmission fluid to each tank of fuel. That dilutes it enough so that there should be no starting or performance issues.
Old 06-14-2007, 05:30 AM   #8 (permalink)
Gregs300CD's Avatar
Vehicle: 1982 300CD
I've filled the filter with ATF with no issues.
I think your immediate problem is air in the lines.
Old 06-14-2007, 09:09 AM   #9 (permalink)
Vehicle: 1981 300CD
I guess I stand corrected on WD 40, but regardless, it does work to start a diesel!
Old 06-14-2007, 09:53 AM   #10 (permalink)
Date registered: Jan 2007
Vehicle: Elvira '84 300CD 216K miles, '82 300SD 246K miles, '74 TR6 78K miles, '99 Land Rover Disco, OBK #27
If you think your internal fuel tank filter is clogged, the simple way to deal with it is to remove the fuel cap, remove the black fuel line that attaches to the input side of the plastic, secondary fuel filter and using an air pressure hose, blow a couple of quick blasts in that fuel line - if there is anything in clogging the filter in the tank, that will clear it.
123Guy is offline   Reply With Quote
My 240d 81 model wont start, heres why. Cobb2 W123 E,CE,D,CD,TD,TE Class 7 02-19-2007 04:43 PM
wont crank after fuel filter change allgoodian Vintage Mercedes-Benz 4 12-12-2006 07:20 PM
diesel wont start after fuel lines and filter change biodieseler W210 E-Class 6 10-29-2006 07:10 PM
Changed fuel filter now it wont start 240D crate W123 E,CE,D,CD,TD,TE Class 10 07-29-2006 11:50 AM
83 240D with greasel kit - wont start dgreenhouse W123 E,CE,D,CD,TD,TE Class 5 06-23-2004 09:02 AM
