anybody got a good source for the halfshaft on 84 300d? i am going to take everyones word for it and not attempt a repair on this one until it is out and car is back FMC. i checked autohauz and they want $352+. i have seen talk of guys getting them cheaper. also, anybody here done the change out before?
do not buy the shit from ebay. Getting 2 used ones from a low mile car with intact boots a also good. Do both axles. Read up on the tricks involved. Ive done it 3 times over the years. Now I'm down to about 4 hours in and out. Plan on putting in new oil seals in the differential and you also get the chance to put in new dif oil and you will learn new swear words when you try to get out the fill and drain plugs. Tip: take out the fill plug first. Don't even think of trying the job without overnite PB Blaster and a propane torch to heat up the plugs real hot.
