» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-13-2008, 08:10 PM   #121 (permalink)
GatoEnFuego
Date registered: Nov 2007
Bboy, car looks great! So that's what 2 coils will look like... I'm in.
As already confirmed the wheels are 16" CLK 320 wheels, they are all aluminum and VERY light. I swear they weigh as much or less than 14" bundts, I held one in each hand. They are not staggered, the front center cap will not fit over the grease cap and there is literally 1/4" gap between the inside edge and the tie rod. I've got a set of 12mm spacers but being so damn low that puts the tire way too close the fender lip for my comfort so I'll probably just "modify" the grease cap to allow the center cap to fit. Anybody want to buy 4 12mm hubcentric spacers with longer lug bolts?
And yes the are stock springs I cut, 3 coils off the front and 1.5 off the rear. Idealy it seems 2 front and 1.5 rear would have been the smarter choice, tis the reason I just bought a new set of front springs to try again. The ride is very near to stock but I can tell I'm past the efficient damping range of the shocks. HDs probably would have helped a bit but probably not night and day. Hopefully bringing the front up a bit will get me more in that usable range and smooth out the bound and rebound when going over small bumps. I have noticed DRAMATICALLY less body roll when turning, it doesn't feel like a boat ready to keel over anymore. Stay fairly flat without being jarring. I think the best route would have been Vogtlands with a coil or two cut that way you get the higher spring rate and drop however the ride will be somewhat harsher.
GatoEnFuego is offline   Reply With Quote
Old 05-14-2008, 12:27 AM   #122 (permalink)
P4olom
P4olom's Avatar
Date registered: Oct 2006
Vehicle: 1982 240d, 2007 e350
Originally Posted by bboybaroo View Post
SLS dropped in the rear (worst idea ever)
Why is that a bad idea? I'm guessing the ride sucks?
1982 240d.
Sienna Pinpoint MB Tex
188,000 miles (as of March 18, 2008)
185,000 miles (as of February 21, 2007)
183,000 miles (as of October 29, 2007)
P4olom is online now   Reply With Quote
Old 05-14-2008, 12:40 PM   #123 (permalink)
SportAuto
Date registered: Jan 2008
Vehicle: lost count at 7
Send a message via AIM to SportAuto
I dont know if i ever posted my car totally finished. This is 2 coils in front, SLS dropped in the rear (worst idea ever) with all the euro gear on it.
Looks good, I've gotta do the front on mine, as it's stock fronts and AMG rears. Check your PM's btw
-Tucker
'82 280TE
SportAuto is offline   Reply With Quote
Old 05-14-2008, 01:02 PM   #124 (permalink)
vipercrazy
vipercrazy's Avatar
Date registered: Jan 2007
Vehicle: 1981 US 280CE
Send a message via AIM to vipercrazy
how is the tire wear, were you able to do a good alignment? im thinking that much of a drop would have the camber adjustment maxed out
7/81 US 280CE M110.984 metallic anthracite grey, tan mb-tex
80 EURO 280CE M110.984 english red, white cloth interior
62 chrysler newport 4DR white 361 V8, 35,100 miles
66 chrysler 300 2DR blue 383 V8, 74,000 miles
vipercrazy is offline   Reply With Quote
Old 05-14-2008, 09:53 PM   #125 (permalink)
GatoEnFuego
Well it's only been 3 days so not too sure of the tire wear. I can tell you however that I have just a bit of negative camber with a lot of adjustment left. I'm waiting until I get my new coils before taking it in for an alignment, but I eyeballed it and so far it feels good on the road.
Old 05-14-2008, 11:30 PM   #126 (permalink)
bboybaroo
bboybaroo's Avatar
Date registered: Jan 2006
Send a message via AIM to bboybaroo
My car is dropped enough that you can not align properly. It wasn't to dramatic but it was definitely beyond the adjustment the car offers.
1983 300TD - 1980 280TE - Bicycle
bboybaroo is offline   Reply With Quote
Lowering kit / lowering springs??? Guest Vintage Mercedes-Benz 1 04-04-2006 06:51 AM
This can't be real.. is it? Snibble W126 S,SE,SEC,SEL,SD,SDL Class 8 11-10-2005 06:03 AM
Is this for real?? coldtaco G-Class 8 04-14-2004 04:26 PM
Are these real or not?? Alam R170 SLK Class 5 02-07-2002 07:15 PM
Get Real Guest (MBNZ) W202 C-Class 2 07-13-2000 03:36 PM
