» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 10-20-2006, 04:45 PM   #21 (permalink)
BenzWorld Elite Host
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
The high ground clearance on stock W123s is needed here in Houston. Houston is sinking, the soil isn't too stable, so we always have potholes, dips, and uneven segments of road between expansion joints. Some lowered 123s look good, but I'm not looking to bust an oil pan.
COME TO THE THIRD TEXAS MB GTG, SAT. JULY 26TH 2008
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is online now   Reply With Quote
Old 10-20-2006, 04:51 PM   #22 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
well hopefully i can fabricate some lightweight aluminum skidplates for a feasable price soon. i'm going to test everything on my car, and with my current stance, i think i'd be a great test subject i am more privaleged living in scottsdale with few dips or imperfections. my mk2 VW was very low, and i rarely scraped anything here. but a trip to my freinds house in west phoenix is suicidal even with factory mercedes suspension!
TUNINGGRüPPE.COM
NüR-SPEC is offline   Reply With Quote
Old 10-20-2006, 04:58 PM   #23 (permalink)
bboybaroo's Avatar
Date registered: Jan 2006
Send a message via AIM to bboybaroo
I would like to know more about the rear end, i don't even know what an "eccentric bushing" is. I assuming chewing up tires from wierd camber settings? Is the only way to fix this with completely new rear control arms? is Kmac katmac or something else? I plan on having a full alignment done after lowering the car, i will also be doing all of my tie rod ends at the same time, will the front eccentric be adjusted through that process or is it additional work? A 2" drop is what i am planning to do. Any less/more can be achieved with the spacers.
bboybaroo is offline   Reply With Quote
Old 10-20-2006, 05:01 PM   #24 (permalink)
bboybaroo's Avatar
So whats the story nur? how did you do it? removed spring spacers i assume? It looks incredible anyway. Is the paint on your car metallic? I loveee the color either way. Might be crazy but i think the black centered pentas would look f'ing mean on the car. That looks like serious fender rubbing material, bumps or no bumps.
Old 10-20-2006, 05:17 PM   #25 (permalink)
NüR-SPEC's Avatar
right now the car doesnt scrape even under hard loads and full lock. it is lowered to the optimal height for the roll center. i did it by cutting coils. many people give this a bad rep because people get carried away. but having less coils increases the spring rate and obviously lowers the ride height and roll center. and yeah, the paint is metallic on my car. it's a very "period" color IMO, but i'd like to do something else. i told myself i wasn't going to own another black car, but 123s look gorgeous in non-metallic black. but i'm still deciding. i'm in no hurry. back to suspension, many people don't realize that even race teams will cut springs for higher rates. i didn't just rip them out and chop them. it was a 12hour job. many measuremnets and math. and as for the eccentric bushings, lose them! remember... heim joints. during my 12 hour all nighter, i also did some investigations and planning for converting to heim joints. i'd like to fabricate stainless steel or very high grade forged aluminum upper control arms with heim joints. but the little trick that makes all the difference is shortening the piece by maybe 1/10 or 1/8 of an inch to regain camber after losing the eccentric bushings.
Old 10-20-2006, 05:23 PM   #26 (permalink)
bboybaroo's Avatar
I am not going the heim joint route. I don't like the noise issue and a diesel station wagon is never going to be a race car, so i dont need to get that into the mods. A 280 coupe i could understand the need though. I don't understand how cutting springs increases rate? and if its true why would anyone EVER by custom lowered springs? I think brown is VERY period and VERY euro. love that ish.
Old 10-21-2006, 11:57 AM   #27 (permalink)
Boardmonger's Avatar
Date registered: Feb 2005
Vehicle: 83 300d turbo, 79 c123 AMG
Now all you need is the euro bumpers and some euro headlights and that car will be sick. I also agree, that is a pretty sweet color.
-Zack K.
1983 300d Turbo (Daily Driver) -- 243,000 miles
1979 280ce AMG (Beginning extreme restoration) -- 141,410 miles
1981 300d Euro 4 speed -- 188,421 km -- Sold
1979 300d Euro 4 speed -- 265,000 miles -- Brother's
1995 E300 Diesel -- 37,000 miles -- Dad's
A Collection of w123 AMG Cars and Parts
Boardmonger is offline   Reply With Quote
Old 10-21-2006, 12:43 PM   #28 (permalink)
bboybaroo's Avatar
Was it standard for coupes to have the rocker panels painted body color? this is not the first time i have seen that.
Old 10-22-2006, 07:00 AM   #29 (permalink)
streetrules's Avatar
Date registered: Jul 2004
Vehicle: W123 560E
No it wasn't. And you should really get airbags. Your driveshafts will break if you have the car permanently low and they're super expensive.
streetrules is offline   Reply With Quote
Old 10-22-2006, 08:36 AM   #30 (permalink)
bboybaroo's Avatar
I know before you claimed set up were about the same, but over here they certainly aren't A good, professional bag setup, that isnt going to pop every month will run about 3,000 installed. If custom wound springs are 400, and a shock steup is 200, that is alot closer to my budget right now. I would love to have airbags. Tell me more about drive shafts breaking and why. And do you mean driveshafts or axle shafts?
Lowering kit / lowering springs??? Guest Vintage Mercedes-Benz 1 04-04-2006 06:51 AM
This can't be real.. is it? Snibble W126 S,SE,SEC,SEL,SD,SDL Class 8 11-10-2005 06:03 AM
Is this for real?? coldtaco G-Class 8 04-14-2004 04:26 PM
Are these real or not?? Alam R170 SLK Class 5 02-07-2002 07:15 PM
Get Real Guest (MBNZ) W202 C-Class 2 07-13-2000 03:36 PM
