Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 09-19-2006, 10:33 AM   #1 (permalink)
Date registered: Mar 2006
Vehicle: 83 300td
83 300td rear toe adjustment??
i have one rear wheel that is toed out, is there any toe adjustment on these rear ends? i see some elongated bolt holes on the bracket that helps secure the front "subframe bolt" ... is that a form of adjustment there? the back end is out far enough that the car actually dogtracks down the road..just enough to be noticed...my brother noticed it one day when following me..he now refers to my car as the Mercedes Bent... haha... R
mercwagon is offline   Reply With Quote
Old 09-19-2006, 04:04 PM   #2 (permalink)
Zedd's Avatar
Date registered: Feb 2004
Vehicle: 80 240D 3.0VNTi
There is no adjustment. You have something broken/worn out. Check all your subframe/trailing arm rubbers including the one on the back of the diff. Also, check your wheel bearing.
That elongated hole might be your problem.
1980 240D 3.0VNT 222k miles
Modifications (Link): OM617.952, 4-speed manual, GT2256V VNT turbo, W115 300D intake, ALDA/EGR/rack limiter removed, 3.46 diff, 15mm rear sway bar, Amsoil bypass oil filter, Mobil1 5W-40 synthetic oil.
"You call parking a supersonic jet in front of a titty-bar 'inconspicuous'?"
youtube.com/Turbo617
http://superturbodiesel.com
Zedd is offline   Reply With Quote
Old 09-20-2006, 04:52 AM   #3 (permalink)
Vehicle: 83 300td
hi Zedd
i looked it over again lastnight, i now realize there is no adjustment, i believe i have a bent rt rear control arm.. ive checked everything else.. bushings...this and that... i have a spare control arm from my parts car.. im gonna swap it out and see what happens... doesnt look like a fun job...looks like the subframe needs to be disconnected and dropped down ..but if this fixes it, it will be worth it.. thanks for the reply..R
rear seat adjustment goburgie W126 S,SE,SEC,SEL,SD,SDL Class 1 01-17-2006 05:34 AM
Camber adjustment? Rear tires? ackvig W140 S-Class 8 08-11-2004 04:54 AM
rear brake adjustment blaine G-Class 1 01-10-2003 11:32 PM
Rear Seat Adjustment - is this even possible??? Darkmann W163 M-Class 12 01-07-2003 07:16 PM
Need to know the alignment specs for lowered SLK, front and rear camber & toe........ Danz R170 SLK Class 0 07-13-2001 07:42 PM
