Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 09-04-2006, 11:03 PM   #1 (permalink)
BenzWorld Elite Host
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Exclamation Ultra Low Sulfur Diesel Facts
Parts of this were previously posted at another forum a few months ago, but given this new surge in requests for info regarding ULSD, I decided to repost it.
This is from a Chevron website, copied and pasted here, but you can read it in its entirety here, which contains additional interesting information about diesel fuel. http://www.chevron.com/products/prod.../L1_toc_fs.htm
Does low sulfur diesel fuel have enough lubricity?
Yes. Even though the process used to lower the sulfur in diesel can also remove some of the components that give the fuel its lubricity, reputable refiners monitor this property and use an additive, as needed, to raise the lubricity to an acceptable level.
Will low sulfur diesel or low aromatics diesel cause fuel system leaks?
The introduction of low sulfur diesel for on-road use in the U.S. was accompanied by fuel system leaks in a very small percentage of vehicles. Investigations into the cause of these leaks suggest that the problem was linked to the change in the aromatics content of the fuel and to seal material and age.
Diesel fuel systems contain "O-rings" and other parts made of elastomeric materials. These elastomers swell slightly when they contact diesel fuel, because they absorb aromatic compounds from the fuel. Exposure to a fuel with a lower aromatics content will result in some of the absorbed aromatics being leached out, causing the elastomer to shrink towards its original size. If the elastomer is still pliable, this shrinkage will not cause a leak. However, if age or service at higher-than-normal temperatures has caused the elastomer to loose its elasticity, a leak could occur. Vehicle owners should be aware that elastomeric parts have finite lives and should be replaced as necessary.
By itself, low sulfur or low aromatics diesel fuel does not cause fuel system leaks. They are caused by the combination of a change from higher to lower aromatics fuel and aged O-rings and elastomeric parts that have lost their elasticity.
Now, here are more links to threads concerning ULSD and ULSD information websites.
http://factsonfuel.org/diesel/index.html#2diesel
http://mbca.cartama.net/showthread.p...1&page=1&pp=15
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline   Reply With Quote
Old 09-05-2006, 12:43 PM   #2 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
online tech links???
NüR-SPEC is offline   Reply With Quote
Old 09-05-2006, 06:24 PM   #3 (permalink)
~BANNED~
Date registered: Aug 2006
Vehicle: 84 300d Turbo
Send a message via AIM to duxdevil
is this stuff okay to use in my old school 84?
duxdevil is offline   Reply With Quote
Old 09-08-2006, 08:04 PM   #4 (permalink)
bmwloco's Avatar
Date registered: Mar 2006
Vehicle: 1984 300CD Turbodiesel
If you're buring Bio-diesel now, Low sulphur should be no issue at all.
Mix it all up, burn it. Keep spare fuel filters and drive on!
bmwloco is offline   Reply With Quote
Old 09-08-2006, 11:04 PM   #5 (permalink)
That's what the aforementioned links are for.
Old 10-25-2006, 02:12 PM   #6 (permalink)
Date registered: Oct 2006
Exclamation
I a fairly recent member of Benzworld, and have not mastered navigating the Forum. Not being aware of this thread already started, I started another thread on the subject of ULSD
HERE on BenzWorld
It's a subject I feel is not getting sufficient media attention and it seems the oil companies may be dragging their feet.
My concern is I have an R320 being delivered in January and hope I don't have problems getting fuel
Steve
MBOW is offline   Reply With Quote
Old 11-05-2006, 09:10 AM   #7 (permalink)
veggie oil as fuel additive
I add .5-1gal of soybean oil to each tank. You can hear the difference. At idel the engine is much quiter and smooother. At $3/gal and diesel at $2.60, I treat a whole tank for $.40.
So soy oil $3, diesel $2.60, peace of mind PRICELESS.
aceofspd is offline   Reply With Quote
Old 11-05-2006, 10:58 AM   #8 (permalink)
Cool
Do you have it in writing from MB that this is an acceptable practice and that you are not invalidating your warranty?
If you have such a document would you post it here for us to see?
In my case, I feel my car is not an experimental machine and I'll stick to the manufacturer's recommendations.
Old 11-05-2006, 11:45 AM   #9 (permalink)
Date registered: Nov 2006
2 MBOW
But actually it is recommended to add abt 0,5 liter of 2 stroke (TCW III) oil to diesel. So the pump and nozzels are lubricated better.
vwt4 is offline   Reply With Quote
Old 11-05-2006, 08:11 PM   #10 (permalink)
MBOW, you should have no problem running your R320 on ULSD. That's the reason it's taking so long for MB to offer new diesels in this market, previously, ULSD diesel was not available so they didn't meet emissions requirements. Now, with the ULSD, we're seeing new MB diesels back in the market. I also think the old fuel would cause problems with you all's new, advanced particulate filters.
This Low-Sulfur Crap is KILLING ME! blackcat1134 W123 E,CE,D,CD,TD,TE Class 5 09-04-2006 11:36 PM
Ultra Low Sulfer Diesel Fuel Availability LNL W211 E-Class 12 08-28-2006 09:08 AM
new low sulphur diesel fuel 84300DTurbo W123 E,CE,D,CD,TD,TE Class 13 10-12-2004 01:33 PM
Low Sulfur Diesels- bad? Ler W123 E,CE,D,CD,TD,TE Class 5 07-02-2003 08:47 PM
Sulfur level in Diesel in Canada/Europe.. Drew, anyone, help ar W163 M-Class 11 11-17-2001 06:44 PM
