Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 07-30-2006, 08:57 PM   #1 (permalink)
cashman's Avatar
Date registered: Jul 2006
Vehicle: 300CD T
Pool of coolant
Hi Folks,
Arrived back from RAGBRAI cycle on sat evening and noticed a big pool of coolant under my car. I drove the car 10 miles on fri night... noticed it didn't reach normal operating temp the last few short journeys and it has been losing water but I thought it was coming from the short fat hose to the thermostat that has perished (new one ordered).
There was no coolant there on Sat morning when I left the house??
I'm Sure there is no water coming out of the seep hole on the pump, which is what I would be lead to expect by the manuals.
I would love to know what's going on.
Thanking you in anticipation
cashman is offline   Reply With Quote
Old 07-30-2006, 09:43 PM   #2 (permalink)
Date registered: Feb 2006
Vehicle: 83 300 d t
Send a message via AIM to washerman
it could come put of over flow tank if it is over filled when car gets hot water expands . you would notice this leak by right side of car
washerman is offline   Reply With Quote
Old 07-31-2006, 09:45 PM   #3 (permalink)
cashman's Avatar
Vehicle: 300CD T
coming from somewhere under waterpump
Cheers Washerman,
Went out and removed the watercap, filled with water and crawled under. The water started coming out straight away in drips from the front of the engine. I wiped all clean and dry and could see a little trickle coming over the lip of the engine from the direction of the water pump housing...
So I think it is the water pump; drat
Will do a search on how to install a new or remanu pump... will let you know how it goes
Thanks,
Paul
Old 08-01-2006, 08:14 AM   #4 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
Been awhile since I've checked, but it used to be that the only safe way to go was to buy a rebuilt pump from Mercedes. They were dirt cheap not too long ago. The aftermarket ones tended not to have the same clearance between the impellers and the housing, causing the car to run too hot. Even if the price difference is more than a few bucks, I would buy the Mercedes rebuilt. Don't forget the O ring too and maybe the gasket.
Len
sokoloff is offline   Reply With Quote
Old 08-01-2006, 01:58 PM   #5 (permalink)
cashman's Avatar
Vehicle: 300CD T
rebuilt
Sounds like sound advice; I'll take a look around for one rebuilt merc water pump.
Thanks sokolof
Pool noodles!!! andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 13 07-11-2006 08:35 PM
Victory For Gene Pool snips Off-Topic 0 03-02-2006 06:04 AM
Would you rent out a home with a pool? lovemyc280 Off-Topic 10 09-23-2005 10:31 PM
Score one for the gene pool.... Chuck V Off-Topic 28 05-24-2004 04:32 PM
OT: Would anyone be interested in Pool for the SuperBowl? Man-Du-Ru-Gas W163 M-Class 3 01-23-2003 03:21 PM
