» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 07-03-2006, 12:41 PM   #1 (permalink)
no-blue-screen's Avatar
Vehicle: 1982 300D Turbo Diesel - 2006 VW Jetta TDI Turbo Diesel
Coolant temp running up..........
Okay,
This is rather complicated scenario, but I don't want to completely overhaul the cooling system as a fix....so here is what is going on:
1982 300D Turbo with 158k on the clock
Problem: The coolant temp is running up higher than it does normally. It hangs around the 3rd hash mark (inbetween the middle mark and the last mark which is labeled 120). It only does this with the A/C on and it only seems to happen at highway speeds.
I am thinking the fan clutch is bad, but I am not sure. I went on a 1 hour drive yesterday afternoon and ran the A/C on max the entire way and I noticed it would hover around that third hash mark and sometimes fall slightly below and then rise again and then fall again. It is my understanding that normal operating temp is 90C, and that operating above this could cause damage to the engine.
Here is what I have inpected so far:
1) The aux fan on the condenser is operating properly
2) The coolant level is normal and there are no coolant leaks.
3) There seems to be a slight wobble in the pulley that the fan clutch is attached to, but again there is no coolant leaking and no wierd sounds that would indicate a failing water pump.
What I am thinking is that the fan clutch is bad, and this is preventing the fan from spinning at full speed. I have the old 6-blade fan on this car and I have already purchased the newer 9-blade fan and a new behr fan clutch.
Given these symptoms and that it only happens with the A/C on and driving on the highway, what do you experts have to say?
no-blue-screen is offline   Reply With Quote
Old 07-03-2006, 01:18 PM   #2 (permalink)
plurkje's Avatar
Date registered: Oct 2005
Vehicle: 1985 300TD Wagon
Check the visco fan with the engine running, open the hood and listen, around 2500RPM you should hear the fan engage. If not you'll need a new one (expensive!).
About the temperature; I think it's pretty normal although it should not climb up when driving uphill.
plurkje is offline   Reply With Quote
Old 07-03-2006, 01:51 PM   #3 (permalink)
Date registered: Apr 2006
Vehicle: 00CLK320 (mine) 00E320 (wife) was 94 & 95 C280 (sold both).
My son 95 C280 had the same high temp gage (when the A/C is on) it's on upper half all the time, the mechanic replaced the A/c fan clutch take care of it. Your diagnostic is good bet (before replaced the a/c fan clutch, I can hear & see the fan kick in), the a/c ran a lot quieter after the clutch is replaced. I can hear the different when I pick up the car.
00CLK208 is offline   Reply With Quote
Old 07-03-2006, 03:15 PM   #4 (permalink)
Thanks for the replies. I have also been googling this subject and it appears the fan clutch is the problem. Thanks again.
Old 07-03-2006, 06:31 PM   #5 (permalink)
Vehicle: 1991 190e 2.3, 1981 300D Euro, 1998 BMW 328i
My '81 300D ran hot at highway speeds also. Diesels generate more heat when pulling loads at faster speeds using more power. The large air flow at around 65MPH usually eliminates the fan & clutch. I found the old radiator had lost its efficiency due to mineral build up internally. Put in a new Radiator (about $200) and Temp ran normally afterwards.......
jmas2k is offline   Reply With Quote
Old 07-03-2006, 07:04 PM   #6 (permalink)
Well, in my situation it is only happening when the vehicle is operated a highway speeds and then it quickly cools down once I pull off the highway and start driving under say 40-45 mph. If it were the radiator, I don't think it would only be a problem at highway speed but it would rather be a constant problem. Anyone else wanna chime in?
Old 07-03-2006, 07:35 PM   #7 (permalink)
Boardmonger's Avatar
Date registered: Feb 2005
Vehicle: 83 300d turbo, 79 c123 AMG
Well replace the thermometer first, that is probably the culprit. With the new fan and clutch and thermomerter the temps ought to stay lower.
My 83 turbo runs between 80-95 and just over 100 on a long hard grade while my euros stick to 90 unless I am going up a big hill or something.
-Zack K.
1983 300d Turbo (Daily Driver) -- 243,000 miles
1979 280ce AMG (Beginning extreme restoration) -- 141,410 miles
1981 300d Euro 4 speed -- 188,421 km -- Sold
1979 300d Euro 4 speed -- 265,000 miles -- Brother's
1995 E300 Diesel -- 37,000 miles -- Dad's
A Collection of w123 AMG Cars and Parts
Boardmonger is offline   Reply With Quote
Old 07-03-2006, 07:43 PM   #8 (permalink)
That is a good idea. That third hash mark, is that 100? I am assuming it is because the last marked hash is 80 and the third hash mark is between the 80 and the last hash which is 120.
Old 07-03-2006, 07:46 PM   #9 (permalink)
I've assumed it is about 100 or so.
First is 40, then about 55 or so, followed by 80, then about 100 and finishing at 120.
Old 07-03-2006, 07:50 PM   #10 (permalink)
Thanks again to all who replied. Will probably work on it this weekend and let you all know the results.
