» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 07-03-2006, 05:41 AM   #1 (permalink)
Ufuk Arpaci
Date registered: Jul 2006
Vehicle: 1979 230 Auto Gas/LPG
W123 rear brakes
my 1979 230's rear brakes not holding good. New calipers andpads.
Any suggestions??
Ufuk Arpaci
1979 230 gas/LPG
Ufuk Arpaci is offline   Reply With Quote
Old 07-03-2006, 07:42 AM   #2 (permalink)
Gregs300CD
Gregs300CD's Avatar
Date registered: May 2005
Vehicle: 1982 300CD
On what type of pad? Or what are you asking?
Gregs300CD is offline   Reply With Quote
Old 07-04-2006, 03:21 AM   #3 (permalink)
Ufuk Arpaci
W123 1978 230 rear brake problem
The problem is :
Front brakes are good.
Rear brakes just keep rolling on.
Please help
Ufuk Arpaci
Samsun,Turkey
Old 07-04-2006, 04:36 AM   #4 (permalink)
Nutz 4 Benz
will post for food
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: To be announced
Air still in the rear brake lines or faulty brake master cylinder/ or brake master cylinder needs to be bled.
Nutz 4 Benz is offline   Reply With Quote
Old 07-04-2006, 06:08 AM   #5 (permalink)
Gregs300CD
Gregs300CD's Avatar
Vehicle: 1982 300CD
Yes, I would think you need to bleed the lines of air.
First, get a piece of tubing that fits over the bleed screw, and a catch can for the old fluid.
Open the bleed screw (8mm, I think) and have a friend step on the brake pedal. Then close the bleed screw, and have your friend let up on the brake pedal. Repeat a couple of times and you should be good to go.
Just make sure you don't run out of fluid in the front reservoir.
