Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 11-22-2005, 08:47 PM   #1 (permalink)
Date registered: Nov 2005
Fuel Delivery Problems '84 230E
While driving my 230E, about 20 mph, the engine died. I was able to re-start the car and drive about a mile farther when it died again and would not re-start. The fuel pump is not working.
I can make the fuel pump work by jumping pins 7 and 8 on the fuel pump relay connector. So, I guessed that the problem was the relay. I replaced the relay, with a used one, but that didn't fix the problem.
When I turn the ignition key I can hear the relay make a click, but the fuel pump does not start.
Any help would be appreciated.
1984 230E 2.3L
Missouri, USA
skylooker is offline   Reply With Quote
Old 11-23-2005, 06:13 PM   #2 (permalink)
architect2's Avatar
Date registered: Nov 2003
Vehicle: Mercedes 1979 280ce
RE: Fuel Delivery Problems '84 230E
20 years of operational from a fuel pump ain't bad. My guess is the click indicates the relay is working, sounds like you need a new fuel pump, (they don't last forever). The cost to test the operation of your 20 year old fuel pump is about half the cost of a new fuel pump. Also consider that when a fuel pump fails it takes a tow truck to get home or to the Mercedes shop.
architect2 is offline   Reply With Quote
Old 11-30-2005, 10:27 PM   #3 (permalink)
Before replacing the fuel pump I checked the voltage going to it. I can turn the key on and I still don't get any voltage to the pump. The only way I get any voltage to the pump is by jumping number 7 and 8 terminals on the fuel pump relay connector, whether the key is on or not. What all is being bypassed by placing the jumper wire? I don't think the relay is faulty. I have checked every fuse I can find. What else can it be? I apprecaite any help.
Old 12-02-2005, 03:06 PM   #4 (permalink)
I still have the problem with the car. Can anyone help me?
Old 12-02-2005, 05:04 PM   #5 (permalink)
MB-Owner-in-ind's Avatar
Date registered: Aug 2004
Vehicle: 77 & 83 300D 85 SD
I don't have a gasser but the fuel pump is usually told to turn on at startup and allowed to run for a set amount of time, about 30 sec.
It doesn't turn back on until you try to start the engine.
Have you tried to jump 7 & 8 and then starting the car?
At this point you really need a wiring diagram or something that explains the operation of the fuel pump.
MB-Owner-in-ind is offline   Reply With Quote
Old 12-02-2005, 08:12 PM   #6 (permalink)
I jumped pins 7 and 8 on the relay connector and the fuel pump ran. I was able to start the car with the jumper in place and run it until I turned the key back off. Thanks for your help. Any other ideas?
Old 12-07-2005, 08:54 AM   #7 (permalink)
The number 9 pin on the relay connector has 12 volts when the key is on, as it should. The ground wire (numnber 11) has been tested and it is a good connection. The problem I'm having is that no voltage is reaching the fuel pump when the relay is in place, only when I jump number 7 and 8 pins.
