» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 05-30-2005, 05:57 PM   #1 (permalink)
Date registered: May 2005
WVO Conversion problem
Hi all I recently installes a WVO conversion in a 240D I purchased for that purpose. The conversion consistes of a rear mounted 6 gallon marine tank with 1/2 in. copper pipe inside to heat the svo and a copper waterline inside the coolant line to a filter and a 6 port valve ( the kind which is activated by 12 vdc to switch over) here lies the problem. the valve appears to work fine however, when I am running on the veg tank the veg tank slowly starts filling up from the return line..(appears to be diesel) how could this be.. I have double checked the valve connections they are correct... Could it be that this valve is not compatable some how. prior to the rear tank install I tested the wvo concept by hooking up a simple 2 gal tank under the hood to the same 6 port valve with a return line and had no backup... Any one have any suggetions... I do like the idea of having the return to the veg tank, so hopefully that will not have to go.... thanks Joe
joepilot is offline   Reply With Quote
Old 05-31-2005, 05:29 AM   #2 (permalink)
Gregs300CD's Avatar
Vehicle: 1982 300CD
RE: WVO Conversion problem
I hear that the copper will become brittle and leak coolant into your yuck. Hope that isn't it. It's always best to go aluminum.
Gregs300CD is offline   Reply With Quote
Old 05-31-2005, 09:30 AM   #3 (permalink)
Date registered: Apr 2004
Vehicle: 1980 250GD Cabrio
The best advice is to skip the WVO conversion and go directly to burning biodiesel. You can phase in the percentage bio-D and this will avoid the problems associated with freeing up all of the gunk in your tank. The benefit of bio-diesel over WVO is that you don't have all of the issues related to coking but you do get the lubricity benefits.
1979 250 GD Cabrio - A very unique machine consisting of a prototype G frame (the only one known to have escaped the factory alive) paired up with a 250D engine. 5 speed transmission (the same one used in the Sprinter van). These are coupled with a prototype 463 Cabrio body that replaced the old rusty 460 Cabrio body. Body is unique in that the tailgate opens like a door on a stationwagon rather than like a truck tailgate. The latest addition is the Schmude 5 piece hardtop that gives plenty of flexibility without having to remove the entire hardtop for open air driving.
1981 300TD
1980 230 GE Cabrio (SOLD)
engnenk is offline   Reply With Quote
