» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W116 S, SE, SEL, SD Class
Old 10-26-2009, 05:25 PM   #1 (permalink)
benz280se's Avatar
Date registered: Jan 2007
Vehicle: 1974 280se w116
1974 116280se type of oil and tranny fluid?
hey folks i am currently saving up to get the valve and head gaskets machined and replaced. what type of oil is the best to run until i can take care of that? i have tried different oils and tran fluid but i don't know the difference. what should i use?currently the car runs pretty good with only a gust of smoke sometimes at startup and a gust of smoke sometimes during extreme acceleration.
benz280se is offline   Reply With Quote
Old 10-26-2009, 08:35 PM   #2 (permalink)
Observer/Master Skeptic
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: Mercedes-Benz & BMW
Change your valve guides to cure the smoke at start up.
Dexron for the transmission
10W30 or 10W40 for oil now
5W-30 or 10W-30 after top end rebuild
Nutz 4 Benz is online now   Reply With Quote
Old 10-26-2009, 11:06 PM   #3 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
Chevron Delo, an oil often used in turbo charged diesel engine, also well suited to our engine, has the old ZDDP additive levels to protect the tappets, lobes etc.in older engines from wear. I like he 15-40.
Other U.S. motor oil makers, incl. synthetic, have quietly reduced the amount of ZDDP.
Good for modern engines build to small material tolerances and with improved metallurgy.
Teutone is offline   Reply With Quote
Old 10-27-2009, 12:07 AM   #4 (permalink)
Castrol makes a classic oil in XL20w-50 with all the ZDDP needed for vintage engines.
http://www.castrol.com/castrol/subse...tentId=7027417
Old 10-29-2009, 04:38 PM   #5 (permalink)
benz280se's Avatar
thank you guys for the info. is changeing the valve guides easy? or should i take it to a mechanic?
Im back fellas with a tranny fluid type quest. 4benzes W124 E,CE,D,TD Class 8 06-23-2008 12:26 PM
1974 280C trans fluid type ? 74280C Vintage Mercedes-Benz 0 04-30-2008 06:06 PM
What type of tranny fluid? MBZBMW R129 SL Class 13 10-22-2006 10:05 PM
What type of tranny fluid do I use? dawiz R171 SLK Class 5 05-20-2006 02:21 AM
HEADS UP: OIL and Tranny Fluid malibuite R171 SLK Class 14 06-26-2005 03:42 PM
