Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W116 S, SE, SEL, SD Class
Old 04-20-2007, 12:30 PM   #1 (permalink)
Date registered: Mar 2006
Smile Where does the tranny vac. line hook up
My 79 300SD has tghe vacuum line to the tranny needing to be reattached to the tranismission. I have looked all over the darn thing and cant find where it hooks up Anybody know I would greatly appriciate it.
dcwier1 is offline   Reply With Quote
Old 09-08-2007, 09:03 PM   #2 (permalink)
JimmyD89's Avatar
Date registered: Feb 2006
Vehicle: '80 300SD
Send a message via AIM to JimmyD89
bump
I was wondering this the other day too...
JimmyD89 is offline   Reply With Quote
Old 09-11-2007, 01:05 AM   #3 (permalink)
Date registered: Jun 2004
On top of the cam cover,is there a little valve device? .it should have hoses to the pump and trans.
mercmad6.3 is offline   Reply With Quote
Old 09-11-2007, 05:25 AM   #4 (permalink)
Date registered: Oct 2005
Vehicle: 79 SD
The w116 did not have the 3-2 vacuum valve switch. I believe the vacuum line should run down the transmission tunnel and attach near the top and front of the transmission, on the passenger side.
This website might provide some insight. New Page 1
Chaw is offline   Reply With Quote
Bubbles moving through in-line filter == leak in supply line? ChuangTzu W123 E,CE,D,CD,TD,TE Class 8 08-19-2006 02:42 PM
screw in vac line sack W126 S,SE,SEC,SEL,SD,SDL Class 3 04-13-2006 06:02 PM
Vacuum line - if I cut the line to the doors and trunk, will it harm anything else? 240-John W123 E,CE,D,CD,TD,TE Class 5 01-26-2006 03:53 PM
VAC SYSTEM Merc600sec W140 S-Class 1 10-18-2004 09:22 AM
Leaking vacuum line and tranny SKullman W123 E,CE,D,CD,TD,TE Class 4 02-10-2004 02:59 PM
