Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W116 S, SE, SEL, SD Class
Old 01-31-2007, 05:16 AM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 350SE
350SE camshaft
I have a 1977 350SE with 103000 easy miles on the odo. There is significant wear on #1 lobe of the R camshaft. What has likely caused this unusual wear as it is not evident on any other lobe on the came camshaft or on any lobe on the L camshaft? Timing chain and associated bits replaced in last 5000 miles. Little distance travelled in the last 7 years.
Powerglide is offline   Reply With Quote
Old 01-31-2007, 09:58 AM   #2 (permalink)
Date registered: Sep 2004
Could be a blocked oil feed to that lobe. The pipe above the cam has small holes aligned above each lobe and oil should run continously onto each lobe. A blocked hole could cause one lobe to wear much faster. The oil flows from the back of the engine so a blockage could be starving the front of the cam.
GaryF is offline   Reply With Quote
Old 02-14-2007, 05:53 PM   #3 (permalink)
supercharger6.9's Avatar
Date registered: Nov 2005
Vehicle: 450SLC
even vorse i have seen to many loose pipes from the plastic where the pipe goes thrue and if it loose the lubrication from the back of the engine cant fill it out all the way so its the same as oil pressure failure you can say in the pipe . soon i will fabricate new ones but in aluminum and there will never be a problem any moore .
Supercharger6.9
supercharger6.9 is offline   Reply With Quote
Old 04-15-2007, 12:06 AM   #4 (permalink)
Vehicle: 350SE
Thanks GaryF - you were right. NOS cam with virgin SH lifter and finger now fitted. Will post photo of worn lobe when I can.
Engine is still rough and down on power. Seems I need a new fuel distributor, and I don't know where to start looking. SH seems like a bad idea without QA, so I need a NOS item. Would a 450SE or a W128 380SE item do the job properly?
Super 6.9 - post when you have oil lines available - but please don't make anything out of old SAAB parts!
Old 04-15-2007, 03:57 PM   #5 (permalink)
hbar's Avatar
Date registered: Feb 2007
Vehicle: 1978 Mercedes Benz 450 SEL
[Seems I need a new fuel distributor, and I don't know where to start looking.]
FYI I just removed the entire Bosch K-jetronic fuel injection from my well running '78 450 SEL to swap in a programmable EFI and was thinking of selling the fuel distributor and other parts on EBAY. I'm not certain that it's the same part as for your 350 SE, but if it is and you're interested, PM me.
hbar is offline   Reply With Quote
Old 08-01-2007, 05:34 AM   #6 (permalink)
Vehicle: 350SE
Thanks, but I'm infirmed that they're not interchangeable. I have had the system rebuilt and some other bugs still need to be ironed out. Will post photo eventually.
- Powerglide
1978 350se? xposednismo Vintage Mercedes-Benz 10 08-04-2007 09:54 AM
Buying a 350SE Franna W116 S, SE, SEL, SD Class 5 01-11-2007 09:19 PM
Feeler: FS 1978 MB 350SE cjbg W116 S, SE, SEL, SD Class 0 09-29-2006 02:14 PM
Can’t I use an MSD on my 1977 350SE EURO? Sr Louis W116 S, SE, SEL, SD Class 2 08-25-2006 06:35 PM
euro 350se on ebay nicko benz W116 S, SE, SEL, SD Class 0 03-18-2006 05:48 PM
