Vehicle: 1980 300SD, 1992 Jetta w/ 2.0 ABA conversion, 1968 Ford LTD and 1965 Ford Fairlane
valve adjustment specs and porceedures?
Guess what... Haynes manuals suck, like i need to tell anyone.
Subject: 300D turbo
If anyone could get me a more detailed guide as to how to adjust valves I would be most appreciative. From what little information I've gotten from my Haynes manual its alot different from an old Chevy or Ford
Althought none of these say it but it is a good thing to
remove your glowplugs before you start this.
Reason being is that if you remove them the chance
of any compression build up is voided.
I will make turning the engine a lot easier.
that is the most informative site i've seen to date. i knew there were some basic maintainence proceedures that needed to be done, for instance, i had no idea there was a power steering filter. i'm going to adjust my valves this sunday (weather permitting). future work will consist of a diesel purge, PS filter change and fuel hose replacement (allready replaced the injector overflow hoses). i wont be surprised to find my valves are way outta spec 'cause my friend i bought the car from never adjusted them and i'm possitive the bumpkin he bought it from never did it either.
