Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W116 S, SE, SEL, SD Class
Old 08-21-2006, 04:30 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1977 Euro-spec 280S
Newbie with a 280S (euro-spec)
Hello all, I've entered the world of Mercedes Benz ownership! I picked up a 1977 Euro-spec 280S. It's in pretty good condition. It had not run in 6 months, I showed up with a new battery and it started right up. Drove it a couple blocks, filled the tank topped off the oil and made my way home...60 miles with no problems. It seems to be running great, even the AC still cranks out some really cold air. I Just came back from the parts store with front and rear pads and the neccesary tune up parts. I'm pretty good with cars and doing my own work but since I've never worked on an old Benz like this I've got a bit to learn, that being said any advise, tips or help will be greatly appreciated.
BTW, here's a few things I'm still not sure on:
Oil pressure gauge - where should it be? When I'm driving the needle stays pinned to the top at 3, sometimes when I stop it goes down to 1.5/2 but it goes right back to the top once I start moving again.
Wipers for headlights - exactly when are they supposed to turn on? I'm thinking teh motors are siezed cause I run the wipers and hit the washers but I get nothing, I pulled one out and tried powering it up directly but got nothing either.
Window movement - they are deadly slow, were they normally like that? If not can I use regular grease or is there something special I have to use?
ace789 is offline   Reply With Quote
Old 08-21-2006, 07:13 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
Welcome aboard ace! I'm gonna slide this over to the W116 section for you.
German Star
GermanStar is offline   Reply With Quote
Old 08-21-2006, 08:06 PM   #3 (permalink)
Date registered: Nov 2004
Vehicle: '91 560SEC
Welcome ace789!
first, as long as the oil pressure gauge returns to 3 upon acceleration (like you said) then you're fine.
second, headlight wipers turn on when the headlights are on and you activate the washers/wipers, if that doesn't work then most likely the motors are bad (like you also said)
lastly, older merc windows are notoriously slow, no they were not normally like that, probably the only real fix is to replace all the motors $$$
good luck
Eli
1991 Mercedes-Benz 560SEC SOLD
1986 Mercedes-Benz 420SEL SOLD
2007 Honda Civic SI SOLD
2006 Suzuki SV650N
benz420 is offline   Reply With Quote
Euro spec vs. US spec headlights & headlight wipers Snibble W126 S,SE,SEC,SEL,SD,SDL Class 14 07-21-2007 10:26 PM
Yellow fogs from US spec to EURO spec? DieselKraut22 W123 E,CE,D,CD,TD,TE Class 2 06-27-2006 01:22 PM
Returning a "USA" Euro 107 back to true Euro spec... bondavi R/C107 SL/SLC Class 14 02-05-2006 02:51 PM
Center Console. NA spec vs. Euro spec Bora20 W164 M-Class 4 12-29-2005 09:38 PM
Euro spec headlight wipers for U.S spec blue420sel W126 S,SE,SEC,SEL,SD,SDL Class 0 03-14-2004 05:23 PM
