Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W116 S, SE, SEL, SD Class
Old 10-10-2005, 06:42 AM   #1 (permalink)
chahonda's Avatar
Date registered: Aug 2005
Send a message via AIM to chahonda
alternator problem
well my 280se isnt charging. is there an external voltage regulator? when i got the car it had an alternator in the trunk as well leading me to believe that the car has had this problem before. i know on some cars there is an alternator fuse. dont see one on this 116. i tried my multi meter and im getting nothing but the battery voltage with no indication of charging. which terminal on the alternator should i be getting 14 volts on? id hate to get a new alternator if i dont have to. maybe ill just wire up a CHEVROLET alternator on there.....i know that will work![:D] thanks for any help i can get
chahonda is offline   Reply With Quote
Old 10-10-2005, 07:46 AM   #2 (permalink)
Der W116 Vorsitzende
Nutz 4 Benz's Avatar
Vehicle: 1985 BMW 635CSi, 1988 BMW 325is, 1995 Jeep Wrangler, 2007 Ford F150, 1994 Suzuki DR350 Dualsport
RE: alternator problem
Yes,there is an external voltage regulator.
Nutz 4 Benz is offline   Reply With Quote
Old 10-10-2005, 10:10 AM   #3 (permalink)
chahonda's Avatar
where is the regulator located?[?]
Old 10-10-2005, 10:13 AM   #4 (permalink)
backside of alternator
Old 10-10-2005, 10:29 AM   #5 (permalink)
chahonda's Avatar
thats what i thought....to me thats considered internal. external to me would mean that its mounted away from the alternator. well looks like i gotta replace the alternator then[:(]
Old 10-10-2005, 10:41 AM   #6 (permalink)
Take it off and get it bench tested at a parts store if
they still do that in the lower 48[:)]You can buy the
voltage regulator instead of the whole alternator if that's all it is.Way cheaper too[;)]
Old 10-11-2005, 05:37 PM   #7 (permalink)
chahonda's Avatar
well i just put on a later model benz alternator on there. a 90 amp unit from a c280[:D]works just fine now!
by the way does this car (1980 280se) have a 3 or 4 speed transmission?[?] best i can tell is that its a 3 speed or does the car onlt take off in second gear when i place it in drive? i know some mercedes are like that[8)]thanks!
