well it seems as if my climate control in my 1980 280se just doesnt want to work. i checked the fuse in the fuse box under the hood but its fine. should i be looking elsewhere?[?][?][?]thanks
Not at all or what?
If you turn it to max temp, set it on defrost and drive around at speeds above around 40 mph does the car get warm? If so then it may be your blower that's bad. If not, it could be the amp (behind the glove box) the servo on the firewall or the push button unit.
John
'80 500SE Euro '5.0 AMG'- 5.0 AMG engine, Gleason rear diff (still trying to find the ratio) and full aero kit. Stock interior. BBS RS133 8x16 3 piece wheels with Michelin XGT Z4 245/45-16 tires.
'78 450SLC milan brown metallic/bamboo leather
'80 300SD
