Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W116 S, SE, SEL, SD Class
Old 09-21-2005, 06:58 PM   #1 (permalink)
Date registered: Sep 2005
Send a message via AIM to w116fan Send a message via MSN to w116fan Send a message via Yahoo to w116fan
280SE tuning?
Hey everyone! Im a 16 year old considering buying a 1979 280SE for cheap. It looks like its in good condition with a new engine. My question is is it possible to get respectible performance (o-60 around 7 seconds w/o nitrous injection) with the I6 it comes with? Would it be best to save up for a V8 or later 6 cylinder or tuning the I6 it comes with? I dont want to spend a huge fortune and it must remain street legal. And yes, I am willing to do internal work if nessary. I just don't want to be slower than my friends 5000 pound 4 cylinder S10 lowrider.
Also, I dont want to remove allot of stuff from the cabin if i can avoid it.
w116fan is offline   Reply With Quote
Old 09-21-2005, 11:39 PM   #2 (permalink)
Der W116 Vorsitzende
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 1985 BMW 635CSi, 1988 BMW 325is, 1995 Jeep Wrangler, 2007 Ford F150, 1994 Suzuki DR350 Dualsport
RE: 280SE tuning?
Swap the 280SE airflow sensor for a 450SE/SEL airflow sensor.The trick to squeezing more power out of the K Jetronic fuel injection is more airflow.
Nutz 4 Benz is offline   Reply With Quote
Old 09-22-2005, 06:23 AM   #3 (permalink)
nomada's Avatar
Date registered: May 2005
Vehicle: 280SE W116, 500SEL V126 (Euro)
Send a message via Skype™ to nomada
RE: 280SE tuning?
Nutz 4 Benz - 9/23/2005 6:39 PM
Really?, tell me more, I read your sticky on rebuilding the airflow sensor, but, is there anything else that can be done for more power?[:p]
Damon 500SEL Euro
Baddest 190 ever! >> http://www.youtube.com/watch?v=rU9mQ7z5JVQ
nomada is online now   Reply With Quote
Old 09-22-2005, 02:56 PM   #4 (permalink)
RE: 280SE tuning?
That modification will really unleash some impressive
power and is relatively cheap.The only thing you'll have to do is add your 6 cylinder fuel distributor to the 8 cylinder airflow sensor.Make sure that the transmission and engine mounts are solid too[}:)]Hint!
Other than that,gut the cat,buy a freeflow muffler and cancel the airbox.Fab a cold air box instead and use a cone type filter with the largest hose to the airflow sensor that will fit.Maybe also find some 8mm
spark plug wires and an R107 differential (380SL/SLC)to increase the acceleration tremendously.
Without rebuilding the engine,there is not much that can be done but with these mods I suggested,the ride will become a lot more interesting.[;)]
Old 09-22-2005, 11:04 PM   #5 (permalink)
nomada's Avatar
RE: 280SE tuning?
Cool man, I'll try these things with my 280 sometime
I'm wanting to power up my 500 (for nada of course)
I've gotten rid of the cats and have put on a cone filter, slightly better gas mileage and coarser exhaust note is all I've noticed from that though
Got any tips for an M117? Apart from the obvious and expensive exhaust system mods
Old 09-22-2005, 11:20 PM   #6 (permalink)
RE: 280SE tuning?
I'm assuming that the filter is absent inside the air box?! I would isolate the cone filter from any engine heat for starters(cold air box).And in the inside of the airbox,remove the mesh screen that goes around the
inside area too.Maybe even mirror and fab the same setup on the other side of the airbox and add a second cone filter.More air equals more power![8D]
Old 09-23-2005, 01:23 AM   #7 (permalink)
nomada's Avatar
RE: 280SE tuning?
Yeah, I did remove the old filter[^]
I might try and put together another neck and second filter or try to get a filter box from a 560 W126 as they have twin necks
Cheers Nutz
Damon
Old 09-29-2005, 06:07 PM   #8 (permalink)
RE: 280SE tuning?
I would not change the differential on the 280SE, it has a 3.69 final drive and the 380 has a 3.07. A Euro 280SE was my first benz. Is the one you are looking at a euro or american? Get a euro, they have higher compression, and no emission crap. 185HP from a 2.8L is not too bad. A good euro 280 can and will beat an american 450SEL (it whipped circle around my 450). The 2.8L engine gets good gas milage and would be an excellent canidate for turbocharging. The only other car I would recommend, but probably isnt the best for a 16 year old is a euro 6.9. A euro 6.9 is hell on wheels.
Good luck,
Phil
Turbo_Phil is offline   Reply With Quote
Old 09-29-2005, 11:09 PM   #9 (permalink)
RE: 280SE tuning?
Turbo_Phil - 9/29/2005 5:07 PM
Good luck,
Phil
A 380 has 2.47 ratio[:)]
Old 09-30-2005, 03:01 PM   #10 (permalink)
RE: 280SE tuning?
a 2.47 will give you top speed but will be slow as all hell off the gun, keep the 3.69.
