I just picked up a 1975 280se and a 1975 450sel both seem to have the 4.5. I like your articles. We met one time at a lot that was giving away cars and talked some about our rides. I have the 82 380sec, with a crap motor so I' looking at one of my 4.5s as a donor but I'll have to learn this systme just like the k-lamba.
Yep! this one is in the garage. It runs somewhat rough and I'm trying to adjust the trigger points and clean the injectors. Have you delt with anyone who has converted these distributors over to electronics. This system seems to cause problems with age. Will this engine work with my 82 126 electronics? I see a pickup off the crank so perhaps it can work with later ecu's.
Hi,
I have the 88 500se. i cant get it start, it has fuel pressure,new fuel distributor and powerful spark. what could it be. need some support out there.
Best regards,
joji
First of all, congratulations on the great info! It is obvious you are masters on this subject. I have a 1985 500 SEL that's been having a lot of problems in this area. First, cold-starting: The engine turns, turns, turns, and it "tries" to start 2 or 3 times before actually doing it.
Second, while in operation: the engine smokes... not badly, just a small fume. When you step on the gas pedal, it smokes a lot... however, at cruise speed it doesn't seem to smoke at all!.
I tested it's compresion and it turned out ok. The dealer says it´s "probably" the fuel distributor or the injectors, and want to change all 8 injectors and the fuel distributor. Now, the problem is that they say they "don't know for sure" if that's gonna solve the problem... and I'm not a big fan of paying lots of bucks just to "see if it works out"! Is there any way I can try to solve it myself? Is there a way to regulate de proportioning valve on the fuel distributor? How about air/fuel ratios? How do I check the cold-start injector? What else could be wrong?
Someone knows how to solve last problem here...?
I also have problems with fuel distributor.It runs perfectly with no gas, while that one injector runs.But when fuel distributor runs, it turns off.
Really good information! I have a question about the hose that goes from the airbox to the inlet manifold at the front end of the engine, it has a gigantic banjo fitting in the engine end.. There's a spring and a big screw, obviously some kind of pressure or flow adjustment is possible here, but what is this?
Question..
What would happen if the throttle linkage was stuck in wide open throttle position and one attempted to start the car?
I believe in EFI systems that the computer would sense that the car is not started and prevent loads of fuel from being dumped in the cylinders, but what about the k jettronic? my car would turn over but not start, so I pulled the plugs and they were soaking wet, and fuel was actually dripping out of the spark plug hole. I then played with the throttle linkage and realized that the connection between the accelerator pedal and the linkage was broken, and the linkage was in the WOT position.
Hello. Very good information in this post. It have been very useful so far.
We have a w116 280se with D jetronic with starting trouble. It is the M110-engine.
The first problem was that the car was hunting at idle. We changed the spark plugs and checked the following: both temp-sensors, pressure sensor (MPC), throttle switch, aux air valve. We also checked for vacuum leaks and that the fuel pump was running. Nothing helped.
But, when we took out the trigger points and cleaned them the problem changed. Now the engine starts but stops after 5 seconds! When it stops, it also stops the fuel pump. We have connected 12v separately but it stops anyway.
We have measured the trigger points when not installed. But my guess is that they maybe are worn down so they won't work when installed and therefore maybe the ECU stops the engine? I also think the cold start valve helps it start, and when the cold start valve stops, the engine also stops?
Vehicle: 1985 BMW 635CSi, 1988 BMW 325is, 1995 Jeep Wrangler, 2007 Ford F150, 1994 Suzuki DR350 Dualsport
Idle air bypass;
It is for adjusting the curb idle.
