The third fuel filter. Where is it? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-13-2016, 08:17 AM Thread Starter
76doubleU115's Avatar
Date registered: Aug 2016
Vehicle: 1976 300D W115
Thank you in advance for the help. I have a 76 300d and am looking for the third filter. I have changed the inline and screw on under the hood. Where is the third one at?
76doubleU115 is offline
post #2 of 8 (permalink) Old 10-13-2016, 08:32 AM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 194 Post(s)
it is in the tank. I believe it is in the middle and removed from under tank it takes an allen wrench to remove
current stable
2010 glk350-86 300e-88 300e white-88 300e blue-66 220seb-74 230-89 560sec white-91 560sec taupe?-92 300te-83 380se parts car- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup- 74 scout-88 jetta karat-74 harley fxe-92 harley flhtcu ultra classic-95 harley road king-96 harley fatboy-98 special construction harley powered.- 2011 klx250 and to many off road vehicles and coming soon 69 280sl
1mbzdoc is offline
post #3 of 8 (permalink) Old 10-14-2016, 07:20 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Either a 16 or a 20mm one, yes. I can never remember which. When you take this out, you'll see a fine mesh most likely clogged after use of crud. My recommendation is to clean it with some acetone (nail polish remover) and put it back in.
And be sure that the tank is empty before removing it, or you'll spill fuel until it is
Grubeguy is offline
post #4 of 8 (permalink) Old 10-14-2016, 10:42 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
I use an inverted spark plug socket to remove them. They are quite tight. I've had to use a 3' "cheater bar" and a pipe wrench before.
Mike D is online now
post #5 of 8 (permalink) Old 10-14-2016, 02:14 PM Thread Starter
Maybe this isn't for this car.
When I bought the car, it came with two of these from the original owner. Have always changed the oil, inline and screw on filters at the same time. And the tank yearly. Just wanted to be sure I wasn't missing out on something important.
post #6 of 8 (permalink) Old 10-14-2016, 08:00 PM
Quoted: 53 Post(s)
The "in-line" filter is actually a baffle.Yes, it does stop large chunks of crap but its primary purpose is to smooth the surging of the fuel supply.
I know, I know, 400 people are going to argue this point but it is true. You would not want a filter before the lift pump because if it clogged the system would run dry. Not a good thing to happen to a diesel injection system. If you are getting particles in the baffle then you have a problem with the fuel tank system. Drain, clean the tank and use fresh fuel. Or you can use a flushing agent and keep replacing filters. Your money and your time, I'm a lazy S.O.B., I only like to fix things once.
Whatever the filter in the picture is, it is NOT the fuel filter for your car. You've got the part number on the box. Do a search.
Listed as a "pre-filter"
76doubleU115 likes this.
post #7 of 8 (permalink) Old 10-14-2016, 08:06 PM
Quoted: 53 Post(s)
Fuel Filter Kit for a 1976 300D
Part #: 000-470-01-92-67-M45
I might be wrong about the separate supplied filter. It might be a good number.
post #8 of 8 (permalink) Old 10-18-2016, 12:33 PM Thread Starter
Thank you Mike!
