w123 Diesel Intermitent start issue. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-09-2016, 08:46 PM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
Hi All
I'm trying to help a friend with his 78 w123 diesel. Basically when he goes to start it, the glow plug light glows then turns off, but when you turn the key Nothing happens. No click or noise what so ever. The starter is brand new. My attention was turned to the gear shift lever on the floor. I was wondering if the car still thought it was in drive? I have had this problem before on my Mercedes. I moved the shifter back and forth then the car would start! So it seems that is the problem. My question is what should I look for? A safety switch? Or a loose bushing? (That's what it was on my car). I am not familiar with the w123 so if there is anything I should know first that would be of great help.
all the best John.
wroding is offline
post #2 of 3 (permalink) Old 10-10-2016, 06:41 AM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
Originally Posted by wroding View Post
Hi All
all the best John.
The W123 does have a neutral safety switch on transmission that is part of starting circuit. Then there is the ignition switch itself. Electrical part is at inner end of starting switch.
When I had a similar problem on my W123, I changed both of above and still no luck. Ended up being the starter itself. But you say car has a new starter and presumably solenoid as well? Did the starter work after it was initially installed? I would try powering the starter directly, with a hand switch to make sure it does work. Then work back.
Kent has a guide here: https://mercedessource.com/problems/...er-the-starter
and Diesel forum at Peachparts and W123 forum here are other great resources.
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is online now
post #3 of 3 (permalink) Old 10-10-2016, 08:51 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Thanks MB Graham. Good idea. when I get a chance I will try that. The main reason I think its the safety switch is that it fired as soon as I moved the shifter back and forth.
All the best John.
wroding is offline
