any ideas how to extract thermal switch from m130 head? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-28-2016, 11:34 AM Thread Starter
Date registered: Jul 2015
Vehicle: 71 280SE
rusty thermal switch twisted and broke off in head..any ideas how to get it out? Thanks
wyeast is offline
post #2 of 4 (permalink) Old 09-28-2016, 05:22 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
I would spray it with an equal mixture of acetone and ATF several times over a day or so and try with an "easy out" bolt extractor. And try heat later if that does not work.
Will
Baybear is offline
post #3 of 4 (permalink) Old 09-29-2016, 05:59 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 460 Post(s)
+1 on the heat. I'd try 20-30 seconds with a torch.
rumb is offline
post #4 of 4 (permalink) Old 10-08-2016, 01:01 PM
nordfisch's Avatar
Date registered: Sep 2015
Quoted: 12 Post(s)
Hi,
The problem is that the thread is tapered and jammed.
You can't heat this as much as necessary...
Use a small saw blade for metal that fits into the hole (we call it 'Puck saw blade' in Germany, ) and cut the tread down to the bottom.
Maybe you have to do this on the opposite side, too.
But you will now be able to loosen the whole threated tube by driving in a solid steel needle between thread in the head / threated tube.
Take care not to harm the thread more than necessary - you will have to use a good sealer afterwards.
Regards
Norbert
nordfisch is offline
