success story - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-17-2016, 02:43 PM Thread Starter
rumb's Avatar
Date registered: Oct 2012
Quoted: 499 Post(s)
success story
A little over a year ago I got my 77 450SEL 6.9. A years work rebuilding and restoring the entire fuel system, engine bay, front wheel wells, and all suspension and brakes I have finally started the engine and got the suspension to rise! All brackets, bolts and fittings have been replated.
A couple of days from now I plan on my first time driving the car.
ID:	1976937   Click image for larger version
ID:	1976945   Click image for larger version
Fonzi and Winegarden like this.
rumb is offline
post #2 of 3 (permalink) Old 09-17-2016, 10:15 PM
Dikdaan's Avatar
Date registered: Jan 2014
Vehicle: 1977 450 SEL 6.9
Quoted: 68 Post(s)
Stellar work Robert! How much drama was involved in that Webasto block heater?
Dikdaan is online now
post #3 of 3 (permalink) Old 09-18-2016, 07:30 AM Thread Starter
rumb's Avatar
Quoted: 499 Post(s)
The webasto went fairly well. mostly just disassembly, cleaning, painting and plating.
The biggest pain was reinstalling it along with the tentacles of hoses. It took 3 tries to get it in with the hoses attached correctly, but now I have one hose fitting leaking and I ended up with the head on the clamp facing a bad direction, so I looks like I have to loosen and pull the whole thing up again. It is very tight territory in the bay once it is installed. Make sure you get all the clamp heads pointed to were you can access them later. It took me most of a year to find the correct fuel pump for it.
I have not actually fired the system up yet, but did for a few seconds turn the clock knob and I heard some fan sounds coming from the unit, which is a good sign. Each separate component of the system tested good, so I hope the entire unit will work. I still need to test that I have the fuel pump connections correctly and that it is supplying fuel to the system.
rumb is offline
