1971 280s stalls out in gear - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-13-2016, 12:13 PM Thread Starter
Date registered: Sep 2016
Hi, I am just trying to get my 280s into the garage so it doesn't continue to rust any further. It has been sitting outside for 10 years or so without moving. It seems to have a fuel delivery problem. It turns over after a minute or so of cranking, but when I put it into gear and press the gas it stalls out. Thanks in advance.
Grusselgrosser is offline
post #2 of 5 (permalink) Old 09-13-2016, 01:05 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 480 Post(s)
You dont mention your location in your profile, so I would guess europe somewhere?
Anyway, a carburetor car sitting for 10 years in a damp climate will be full of issues. Rust in gas tank, clogged filters, carburetor in need of rebuild. etc. As a minimum, I would think the accelerator pumps are buggered. You can take the top cover off and see if they are stuck in the bores as they will tend to do. The leather gasket can bond to the bore, so soak in wd40 and try and get them to move again. Dont just rip them out as they will probably tear and the replacement rubber ones pretty much dont work.
If you just want to get it in a garage then I suggest pushing it in.
If you want to get it running again, then you need to go over the entire fuel system to get it in order.
Scoot likes this.
rumb is offline
post #3 of 5 (permalink) Old 09-13-2016, 07:03 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1717 Post(s)
A word of warning... Don't crank too long or you can burn up the starter solenoid wire. I did this to a 1970 250c with the same engine and carbs after I cleaned and rebuilt the carbs. It was a fun adventure, but the car ended up a parts car. Mine also would not stay running when I put it in gear. I only got it half way around the block once.
You will want to take your time and really learn the dual zeniths or find someone who really knows them.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #4 of 5 (permalink) Old 09-13-2016, 07:03 PM Thread Starter
Thanks for the response. I am in the United States. So I got the car into the garage under it's own power but it was difficult. At first, it was stalling out whenever I tried to put it in gear and press the accelerator. After a few more tries it would no longer stall out but it still wouldn't move. I could feel it trying but it just couldn't do it. It budged, but something was holding it back. My driveway is on an incline and even after I put it in neutral and then reverse, it was unable to move. (Parking brake was off of course) After a couple tries I was able to reverse and then put it in low gear and make it into the garage. At first I was thinking the transmission was bad but since the car wouldn't even move on an incline in neutral I was starting to wonder if the years of sitting outside had caused so much rust and corrosion that the wheels brakes and other parts of the driveline had partially seized up. I would like to get the car running but I don't want to spend a fortune.
post #5 of 5 (permalink) Old 09-14-2016, 03:57 AM
kdjones99's Avatar
Date registered: Jul 2010
Vehicle: 1967 250SE (W108)
Quoted: 4 Post(s)
Jack it up and see if the wheels turn. I'd bet it was the rubber brake lines. They are notorious for deteriorating internally making them act as a one way valve. You can do a search on this site to see several discussions about this.
kdjones99 is offline
