1968 280S revival - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-29-2016, 10:12 PM Thread Starter
Date registered: Jan 2007
1968 280S revival
I have a 1968 280S (w108) project, I bought it as a non-runner. I put a fresh battery and nothing happened, no clicks, no whirs just utter silence. So maybe the starter is bad but before taking out the starter I decided to fill the bores with Marvel Mystery Oil to lubricate the rings and loosen things a bit. I also took the cam cover off and poured some MMO on the valve train and the timing chain. Now I want to rotate the crank by hand (or see if it will rotate and the engine is not seized) but having a hard time getting a socket on the crank nut, not much space. Next step is taking out the radiator, fan, and shroud. Any tricks to doing this and what should come out first. At the moment I am in the process of loosening the four 10mm nuts holding the fan.
Thanks
Jorge Garcia is offline
post #2 of 6 (permalink) Old 08-30-2016, 10:23 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1719 Post(s)
I thought I put the 27mm socket with an extension on the crank easily on my 1969 280s parts car pretty easily from under the car. My memory may be failing though. Maybe the motor mounts were shot. Maybe I had it jacked up.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 6 (permalink) Old 08-30-2016, 06:53 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
On my '70 280sel, I remember having trouble from below due to the shroud. I was able to get a deep well 27mm socket on the bolt from the upper driver's side through the fan blades, but it was a knuckle cutter. Doable, though.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #4 of 6 (permalink) Old 09-01-2016, 02:17 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
Originally Posted by Jorge Garcia View Post
I put a fresh battery and nothing happened, no clicks, no whirs just utter silence. So maybe the starter is bad...
Quite honestly I think it might be easier getting to the starter than to the crank. I think that the starter should engage (solenoid) even if it can't turn the engine. So to my mind, if you hear nothing then no power is getting to the starter...
You might want to test power to the starter and power (with ignition switch in start) to the solenoid... If there is room there to do this safely, I think you can jump the starter cable to the solenoid to crank the engine.
I assume your car is an automatic? If so, you need to check that the neutral/park safety switch isn't the problem.
When you turn the key to on, do the oil pressure and amp lights come on? (wait, maybe there is no oil pressure light...) Something on the cluster should be lit up when key is on and car is not running.
jhbrad likes this.
Scoot is offline
post #5 of 6 (permalink) Old 09-01-2016, 02:18 PM
Scoot's Avatar
Quoted: 121 Post(s)
Also, do OTHER electrical things work (lights, horn, etc). Are you sure your new battery has a good ground...?
jhbrad likes this.
Scoot is offline
post #6 of 6 (permalink) Old 09-03-2016, 09:07 PM
jhbrad's Avatar
Date registered: Aug 2007
Very good thinking, Scoot!
jhbrad is offline
