W115 Purchase - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-22-2016, 10:15 AM Thread Starter
Date registered: Jun 2013
W115 Purchase
Hello All,
New to the forum and have just purchased a W115 that I will begin digging into this weekend.
1971 220 with 2.2L gas and 4 spd. 76K. USA model.
First order of business is there is some sort of rubbing noise coming from the front belts/wheels area. Not internal to engine. I am planning to go in and tighten down anything down that is loose but was wondering if there is anything in particular I should target first.
Thank you!
Drew
drewvw is offline
post #2 of 6 (permalink) Old 07-22-2016, 12:52 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 36 Post(s)
Welcome and congratulations. One recommendation is to fully fill out your profile so on future posts, others will know your car.
So, rubbing noise....while idling or while driving? Speed dependent? Vehicle speed or engine speed? Does it change if you are turning or going straight?
At this point, it could be anything
TZ_280SEL is offline
post #3 of 6 (permalink) Old 07-22-2016, 01:58 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 167 Post(s)
That noise on my old W115 was the a/c clutch. Slip the belt off to see if it goes away.
rocky raccoon is offline
post #4 of 6 (permalink) Old 07-22-2016, 03:30 PM Thread Starter
Thanks I will fill it out. Figure I'll be searching/posting here quite a bit.
I did some investigation and it appears to be the fan clutch. New one seems relatively cheap from pelican. Not sure if there is a better option, I'm used to using them for an old air cooled porsche.
Now I'm off to search for engine oil reocmmendations. Thank you!
drewvw is offline
post #5 of 6 (permalink) Old 07-22-2016, 08:06 PM
Date registered: Aug 2009
Quoted: 53 Post(s)
Dump the fan and go with an electric fan.
Change the points set-up to either a Pertronix, HotSpark or the Crane Fireball XR optical trigger.
Chevron Delo 400 15W40 or the Shell Rotella line 15W40. These are both diesel rated oils which have the additives your engine needs.
Use at least the mid-range gasoline blends. RUG will work but the higher octanes will give you a better performance. No need for the premium.
NGK BP6ES plugs work well.
I've got a brand new cap and rotor you can have for shipping cost. I changed to a different ignition set-up so I have no need for them.
Congratulations! Now kiss all that spare time and extra cash you thought you had good bye!
Mike D is offline
post #6 of 6 (permalink) Old 07-23-2016, 03:58 AM Thread Starter
I don't have any spare time or cash!! This is awesome thank you all. I'll take as much info as I can get.
drewvw is offline
