cheap replacement rad - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 07-19-2016, 05:04 PM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
hello all. my rad has sprung a leak and i was wondering if thereis cheap aftermarket rads available anywhere. also is there any other model or make that might fit, mazda gm anything at all. its for a 114 by the way
thanks jimmy
madmanmerc is offline
post #2 of 13 (permalink) Old 07-19-2016, 05:12 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
thanks jimmy
Have you considered getting rad repaired? Might be the least expensive option. The older ones had metal tanks and were better quality than some of the modern plastic stuff.
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is offline
post #3 of 13 (permalink) Old 07-20-2016, 02:28 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Try summit racing - TONS of stuff. Give them dimensions and have them find one for you. You likely won't Find a GM or other new one as a perfect, direct replacement but you'll have tons of options.
Grubeguy is offline
post #4 of 13 (permalink) Old 07-20-2016, 07:01 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
I had my radiator for my W108 re-cored. I think it was less than $200 and the new core is a higher fin count. Works great and I have the benefit of having the original upper and lower tanks so trans cooler and the necks are unchanged. Unless you have badly damaged tanks, I would re-core.
TZ_280SEL is offline
post #5 of 13 (permalink) Old 07-20-2016, 04:21 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1763 Post(s)
Be sure to use a shroud with whatever you use.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #6 of 13 (permalink) Old 07-21-2016, 11:08 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
How do you find a shroud for a Fintail?
Scoot is offline
post #7 of 13 (permalink) Old 07-21-2016, 11:10 AM
Fonzi's Avatar
I think the OP says its for a w114. I can't recall whether the 6-cyl use them, but I know the w115 diesel I parted had one.
Does a fintail not have a shroud?
My signature:
Fonzi is offline
post #8 of 13 (permalink) Old 07-21-2016, 11:13 AM
Scoot's Avatar
Quoted: 126 Post(s)
Yes, he asked about a W114 which would probably be a 2.5L 6. I'm thinking of my fintail, which has an M180 2.2L 6 and a very different shaped radiator than a W114. Tall instead of wide.
Scoot is offline
post #9 of 13 (permalink) Old 07-21-2016, 07:27 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
Its a 250c
post #10 of 13 (permalink) Old 07-21-2016, 07:37 PM
Fonzi's Avatar
Its a 250c
Just curious, does it have a fan shroud?
What year is it?
It could be a 2.5 or 2.8...
Edit: oops. 1970... Probably a 2.8. My 2.8 number 169 was a 1970. That's the 250c those carbs were for.
My signature:
Fonzi is offline
