issue with front carb - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-19-2016, 04:55 PM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
hello all. I have been working on the carbs for a while and they seem to be coming along, however I notice that the gas doesn't go into the front carb like a spray as in the back carb, it seems to come in more as drops, kind of like a slow steady pour, I took them apart a while back and soaked them for a few days in a degreaser and cleaned them well. i also changed all gaskets, seals ect. no idea whats going on. anyone? anyone? lol
thanks, jimmy
madmanmerc is offline
post #2 of 9 (permalink) Old 07-20-2016, 08:11 AM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
Hi Jimmy. What brand / type of carbs are you working with?
Luna Gaudi's 72 250 is offline
post #3 of 9 (permalink) Old 07-20-2016, 09:45 AM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
sorry, its the zenith carbs for the 250c
post #4 of 9 (permalink) Old 07-20-2016, 04:24 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1717 Post(s)
The spray you talk about... Is this the accelerator pump? Or one of the other sources of fuel?
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #5 of 9 (permalink) Old 07-20-2016, 06:55 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
When i give the car gas, instead of a jet its more like a drizzle
post #6 of 9 (permalink) Old 07-21-2016, 05:17 AM
Fonzi's Avatar
That sounds like the accelerator pump nozzle to me. As you push the throttle down, a spray should come from the accelerator pump, but if the seal is bad (common for the original leather seal to fail), it will need to be replaced. The blue neoprene seal that you get in the rebuild kit is not as good as the original leather and seemed to fit loosely in my case.
https://youtu.be/f0tRig2RxrY
https://youtu.be/_Iq30fk70C8
My signature:
Fonzi is offline
post #7 of 9 (permalink) Old 07-21-2016, 08:45 AM
Quoted: 17 Post(s)
I used a guitar string to push into the brass nozzel and it helped to clear out mine when it had the same symtoms. Fuel with ethanol can cause these build ups of sludge if the engine sits with out running for a while.
post #8 of 9 (permalink) Old 07-21-2016, 07:26 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
Thsnks guys. Fonzi, i was wondering where you got those videos from? Did you just make them?
post #9 of 9 (permalink) Old 07-21-2016, 07:35 PM
Fonzi's Avatar
Yes. When I'm doing something new to me that isn't common sense and haven't seen a video, I try to make one usually. I never got those bastards working right on that car. I think the car may have had engine problems with tons of blow by. I never did a compression check on it and really should have. I drove it around the block once, mostly downhill.
My signature:
Fonzi is offline
