Transmission Fluid Leak - 1977 280SE (W116) - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-16-2016, 03:44 PM Thread Starter
Date registered: May 2016
Vehicle: 1977 280SE (W116)
Quoted: 2 Post(s)
Hello, everyone -
Today my 1977 280SE (W116) abruptly developed a transmission leak. I can't imagine they are related but yesterday I had to adjust my fuel mixture and idle settings to pass Colorado emissions testing. (You can view the thread here)
Shown below is the leak in action. It is definitely coming from above where it is actually dripping off the car but I can't see exactly where it starts. My good jacks and stands are currently in storage so I can't get all the way under. It only leaks while the car is running. I checked the fluid level at the end of May when I purchased the car and it was fine. The car has never dripped any fluids before today (it does consume a little oil though). It about a 1/3 of a quart to bring the transmission fluid back up to spec.
Any insight on where to begin would be much appreciated. Thanks!
tristankelley is offline
post #2 of 4 (permalink) Old 07-16-2016, 05:24 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 499 Post(s)
When you can, wash the area off with a strong stream of water or maybe use gunk cleaner or simple green, then you can better see where it comes from. I think there are a bunch of diff o-rings used to seal the openings on the trans like that large round disc just above the leak. first we need to figure out where the leak is. I think old cars that sit and then are started to be used again can have rubber seal problems.
Teutone likes this.
rumb is offline
post #3 of 4 (permalink) Old 07-16-2016, 07:13 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1069 Post(s)
Originally Posted by tristankelley View Post
Hello, everyone -
BTW, If you scroll down the forum index, there is a W116 forum
Teutone is offline
post #4 of 4 (permalink) Old 07-17-2016, 07:03 AM
rumb's Avatar
Quoted: 499 Post(s)
W116.org is very active and helpful.
rumb is offline
