W114 antenna - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-10-2016, 02:35 PM Thread Starter
tewfiks's Avatar
Vehicle: Many MBZ, Couple of 911s, couple of pick ups
Quoted: 49 Post(s)
W114 antenna
Hello,
Can somebody help me with instructions on how to remove an antenna from a 1972 250? It is a 114 sedan. I can not seem to find access to the antenna from either the fender nor the passenger compartment.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
11 E350 4matic Wagon
tewfiks is offline
post #2 of 4 (permalink) Old 07-10-2016, 10:19 PM
Date registered: Aug 2009
Quoted: 53 Post(s)
There is an inner fender well panel which you remove. I believe it is 4 bolts.
You can then remove/tighten the antennae from there.
Mike D is online now
post #3 of 4 (permalink) Old 07-13-2016, 08:31 PM Thread Starter
tewfiks's Avatar
Quoted: 49 Post(s)
I assume access to this panel is from the wheel well?
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #4 of 4 (permalink) Old 07-14-2016, 08:33 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
Correct! Turning the wheel or removing it will give you more working room.
Will
Baybear is offline
