W108 4.5 voltage regulator issue - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-08-2016, 01:17 PM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
Now that I have an actual voltage indication (via my megasquirt), I have discovered a strange issue. Periodically, the voltage on the system will spike from the normal 13.5 volts to 15-16volts. It will stay there for a second or two and then return. It does this randomly and it is an actual voltage transient as it is accompanied by a change in headlight brightness and engine sound.
Alternator is only 15,000 miles old. I swapped the voltage regulator with a new one I had purchased a while back....same story.
I am assuming there is a momentary open in the sensing line to the battery. Is this a valid assumption? Not sure what else could be causing my issue.
Any thoughts?
TZ_280SEL is offline
post #2 of 15 (permalink) Old 07-08-2016, 04:20 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1805 Post(s)
I don't know, but I know my 4.5 needs a new voltage regulator. The low beams both blew when I hit a bump in the road and and my old battery old battery was bubbling. That's when I decided to take a look at the colts. Hmm... Steady ~16+volts. Yikes!
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 15 (permalink) Old 07-11-2016, 12:36 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
Aren't the regulators internal to the alternator these days? My previous searches for separate regulators came up with zilch ...
Grubeguy is offline
post #4 of 15 (permalink) Old 07-11-2016, 01:44 PM
Fonzi's Avatar
These days, and even in the later 70's 4.5 motors, but not the w108 4.5 which are the equivalent to the 4.5 in the early North American R/c107. These have external voltage regulators. On the w108 it is right behind the d-jet ECU on the passenger side (as I believe all 4.5 w108 are North American models, perhaps developed to meet emissions standards, as the 3.5 is actually more powerful).
You can tell the difference in the 4.5 alternators based on the plug on the back apparently. I sent all the 4.5 alternators I had to @rockcrusher in a flat rate box a few months ago. Perhaps he could have more details if needed.
My signature:
Fonzi is offline
post #5 of 15 (permalink) Old 07-12-2016, 05:47 AM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
So, problem solved. It is actually the alternator which is bad, but not for the normal reasons. The plug on the back of the alternator is held in place by a couple of plastic tabs, or should I say it is supposed to be held in place by a couple of tabs. My plug is being held in place by force of habit, which is not strong enough apparently.
When you wiggle the plug, voltage will spike to about 16-17v and then you wiggle it again and it comes back to 13.5v.
I did make a new harness from the alternator to the regulator as the old one was pretty beat up. All three wires into the alternator had their insulation broken from fatigue at the connector. One of them only had about a third of the copper strands left in tact.
So, alternator on order, new regulator, new harness....hopefully case closed.
rumb likes this.
post #6 of 15 (permalink) Old 01-03-2017, 02:26 PM
Premium Member
Droidster's Avatar
Date registered: Nov 2013
Vehicle: 74 450SL 107 044 12 020684 73 280SE 4.5 108 067 12 021470
Quoted: 176 Post(s)
Premium Member
My battery recently died, I recharged it and checked the voltage with my multimeter and it was jumping all over the place. I suspected my voltage regulator and a new one is on its way, but just found this thread. I'll check the plug on the alternator as well.
Just curious, after replacing those parts, has it solved your issue?
Droidster is online now
post #7 of 15 (permalink) Old 01-03-2017, 02:57 PM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
Yes, after replacing the alternator, my issue is solved.
post #8 of 15 (permalink) Old 01-03-2017, 03:12 PM
Premium Member
Droidster's Avatar
Quoted: 176 Post(s)
Premium Member
Good to know, thanks so much!
post #9 of 15 (permalink) Old 01-03-2017, 05:44 PM
Fonzi's Avatar
I had two electrical issues on my w108. First the insulator on the bracket that holds the wire from the battery to the starter failed. Then the metal of the bracket chewed through the insulation on the wire. That's when I got huge sparks, and whole bunch of the insulation melted off the wire. It's interesting how sparks and fire under the hood can be such a bad thing.
As a temporary solution (after disconnecting the battery), I wrapped the wire in duct tape until I could replace the starter wire.
Then one day I was driving in some very cold weather on a very bumpy road. Both headlights went out at the same time. Then I popped the hood in my driveway to take a look and I heard the battery boiling. I was running around 17-18 volts. I disconnected the wires on the alternator until I could get to the voltage regulator issue. Replacing the external voltage regulator solved the problem.
That's the way I remeber it anyway.
My signature:
Fonzi is offline
post #10 of 15 (permalink) Old 01-03-2017, 06:10 PM
Premium Member
Droidster's Avatar
Quoted: 176 Post(s)
Premium Member
:flushed::flushed::flushed:
Thanks for the reminder. I'll be checking the harness as well as I've seen some insulation that has degraded.
