buying decision - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-27-2016, 09:21 AM Thread Starter
Date registered: May 2014
Vehicle: passat wagon
buying decision
HI all, am looking for a w114/115, found two of them near one a 1970 220 manual, the body is in nice condition but the engine have not run for years the one is a 1975 240D automatic, in running order but with rocker and interior needs. not sure which one to get, ant particular problem with either the M115 engine or the automatic transmission??
regards
britishrocco is offline
post #2 of 7 (permalink) Old 06-27-2016, 02:31 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1805 Post(s)
It sounds like maybe you can make one good car from the two... Maybe. I recommend continuing your search. Always buy the best example you can afford because it will save you time and money. "There's nothing more expensive than a cheap Mercedes."
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 7 (permalink) Old 06-27-2016, 05:24 PM
Date registered: Aug 2009
Quoted: 72 Post(s)
Rust is the killer of the stroke eights. Just like an iceberg, 80% or better is hidden.
The 240D has the "better" engine, especially since it is running.
The M115 4 cylinder, coupled with a manual transmission, can be surprisingly "perky".
Unless you are looking for a project car, I'd take Fonzie's advice and pass on these two.
Mike D is offline
post #4 of 7 (permalink) Old 06-27-2016, 05:41 PM Thread Starter
Am indeed looking at a project, am a mechanic and my thought was to get the best body I can get.
Sent from my XT1575 using Tapatalk
post #5 of 7 (permalink) Old 06-27-2016, 06:04 PM
Fonzi's Avatar
I never owned (a running version of) either of those engines, but got sick of trying to tune dual zeniths in a worn out m130. It was my only experience with MB carbs and I left w114/115 behind and haven't looked back (much). There was a short period where I had a good injected m110 and a manual trans Kit for a w114/115 and thought again about how I would have put those in that w114 coupe if I'd had all three at the same time. Otherwise, I really haven't looked back, but do still keep my eyes peeled for good 1973 cars that don't have the diagonal braces in the engine compartment yet are still the earlier style that I think is cooler.
I think I'd have to either have a stick of hot rod a w114/115 if I owned another.
So if you get the stick shift, the one cool thing you get is the majority of the stuff you'd need if you want a stick.
My signature:
Fonzi is offline
post #6 of 7 (permalink) Old 06-27-2016, 11:27 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 130 Post(s)
If you want a good mechanic project then avoid anything with rust. Also decide whether or not you are going to tolerate the slowness of the 4 cylinder diesel. Having said that, the 6 cylinder gas cars are kind of a pig at the pump. For "coolness" factor I would go with a W114 coupe. I think they are tremendously undervalued.
I'm sure if you take some time you can find a car with a good body and a dead engine. That's much better for someone who is a mechanic. It is not a good idea to buy the first car you see. Look at a lot of them (if there is inventory) before you decide. You are going to be stuck with it for a while...
cheers.
Scoot is offline
post #7 of 7 (permalink) Old 06-28-2016, 04:52 AM
Quoted: 72 Post(s)
The M115 is a good solid engine. Mated to the 4 speed manual transmission they'll zip right along.
Been running a M115 in my wife's '71 250C (originally equipped with the M130 automatic) for over 6 years now and it is a hoot to drive.
Peaks out at about 85 MPH but will run at 75-80 MPH all day long. One of these days I'll get around to swapping out the 3.69 differential it has to a lower one. 1st gear in it is pretty useless unless you're looking to climb trees.
The only problem I've had with the M115 was the valve guides. When I got the engine a couple of them had become loose and wallowed out the head. Got a replacement head and it's been running ever since.
Avoid the M115's with either Solex's or Zenith carb. The simple old Stromberg side draft carb is the way to go.
Mike D is offline
