Stuck: W108 Mercedes 250S Head Torque Specs and FSM - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-23-2016, 06:43 PM Thread Starter
Date registered: Jun 2016
Vehicle: 1966 Mercedes 250s
Hello Benzworld,
I don't know why I never signed up before, but it's possible because most information is available without signing up. It's been a few years since I purchased my 1966 W108 and I just started working on it. Now that I've finally started wrenching on it I'm having the hardest time finding torque specs for the head and a legit copy of a FSM. I also have a few bolts that I can't seem to locate. One of them being for the timing chain sprocket(Pretty sure that's not the actual name). It seems as if the bolt needs to have a two step thread pattern.
Thank you in advance for any help!
mr_meyers is offline
post #2 of 2 (permalink) Old 06-24-2016, 12:06 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
There is a lot of info here:
MB Classic sells a cd set with workshop manuals for W108's.
Haynes manual is pretty good, should have your torques spec in it.
the cam bolt is N 000960 014010, though you probably need to get it from a wrecker
the cam gear is 121 052 03 01
rumb is offline
